87 325 Fuel pump issueFratz 12-31-2004, 03:24 PM 03/87 325 No voltage to external pump. Relay was bad = replaced. With wires disconnected from pump and starting = 10 vdc on the two pump wires. When wires connected to pump and starting = 0 vdc??? 12 vdc directly to pump from battery and pump runs. Internal tank pump is OK. UPDATE: Now no pwr. at pump when starting. Relay still ok. Is there more than "1" relay involved? Poor Haynes book in hand. MORE Update: Main relay stays energized with key OFF. F11 reads 0.5 vdc with key on. No continuity from 87 to pump Any clues? Thanks, Fratz crash8168 12-31-2004, 07:13 PM You have a voltage drop caused by high resistance in the wiring somewhere. jeffreyb4me 12-31-2004, 08:04 PM you have a "Main Relay" and a "Fuel Pump Relay" and fuse ? 17 I think...........anyway, the pump relay has 4 connectors one of which will have two green/violet wires coming off it. The Main Relay has 5 terminals with large red, red/white and red/blue wires coming off it. Replace Both relays and see what you have.........also replace the pump fuse, just can't remember it's number.........F11?........F17?..........jb. Fratz 01-01-2005, 03:28 PM crash8186 / Jeffrey, Thanks for the replies. Found the 87 line splice that branches to both pumps under the rear seat had failed/burnt. My 325 has been resurrected from the dead. Last question: The fuel pump main relay stays energized with the key OFF. It appears to get it's ground from the MCU. Normal? Again...thanks for the assist. Fratz jeffreyb4me 01-01-2005, 08:58 PM The Main Relay IS energized with the key in start or run..............the Fuel Pump Relay should ONLY be energized in START or with the engine RUNNING !....[should not be energized with the key on, engine off !] Automotive Network, Inc., Copyright ©2012
