Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche/C&K/Silverado/Suburban/Tahoe > C/K
Old 12-30-2004, 11:03 PM   #1
roonie
roonie Normal reputation
cylinder compression 90 chev 305
what should the cylinder compression be on my 90 chev with a 305.I did a dry test and ended up with 75 lbs.at each hole.that seems a bit low to me.what would it have been from day one.runs nice but using some oil.have already done valve seals.no longer puffs apon starting.thanks
roonie is offline   Reply With Quote
Old 01-19-2005, 01:36 PM   #2
tirefryer93
tirefryer93 Normal reputation
Re: cylinder compression 90 chev 305
You are right, 75 lbs is low. Stock should be anywhere from 130-150. My inclination is that your rings are worn, which is reasonable because of your loss of oil and low compression. Unless you want to give the engine a partial (or entire) rebuild, I suggest using some engine flush in your oil, drain it, then add a new change of Valvoline (best thing for chevys) and try a quart of additive such as Restore or similar. That should help seal the cylinder walls better and give you some better numbers on the compression gauge.
tirefryer93 is offline   Reply With Quote
Old 01-19-2005, 05:05 PM   #3
Fireplug
Fireplug Normal reputation
The main thing about a compression test is that they are all about the same reading. 75psi is low but if its running good and does not burn a lot of oil then run it.
Fireplug is offline   Reply With Quote
Bookmarks
Google
Web AF
