Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Ford > F Series
Old 12-30-2004, 09:49 PM   #1
charman420
charman420 Normal reputation
Help!!! Truck not starting... I've tried everything
My truck died. I've replaced the fuel pump relay and EEC relay, thinking that was the problem, but it wasn't. I have spark, and the inertia switch is good. I bypassed the fuel pump relay for power to the pump,and it still won't start. I don't know what else I can do, any suggestions would be great
thanks, Sean
charman420 is offline   Reply With Quote
Old 01-02-2005, 08:46 AM   #2
97chevyman
97chevyman's Avatar
97chevyman Normal reputation
Re: Help!!! Truck not starting... I've tried everything
chekc your fuel pressure, just push the release with the key on.
2000 ford F-250 4x4 CC auto
1978 F150 4x4, 6 inch lift painted john deere green
97chevyman is offline   Reply With Quote
Old 01-04-2005, 08:40 PM   #3
charman420
The problem is that there is no power to the fuel pump.
Old 01-04-2005, 10:07 PM   #4
StillTruckin
StillTruckin Normal reputation
So give it power.
StillTruckin is offline   Reply With Quote
Old 01-05-2005, 01:24 AM   #5
ModMech
ModMech's Avatar
ModMech Normal reputation
Year?
ModMech is offline   Reply With Quote
Old 01-06-2005, 03:00 PM   #6
charman420
truck is a f-250 1986.
Old 01-07-2005, 01:22 AM   #7
ModMech
ModMech's Avatar
Check the wire harness connector (1" square about) under the master cylinder. It is VERY common for the connectors to corrode and fail there. Also, the connector under the driver's seat on the inside of the left frame, check that for power as well. From there it is straight to the in-tank and frame (main) pumps.
Old 01-16-2005, 03:02 PM   #8
patpaolo
patpaolo Normal reputation
I am also having a fuel problem with a 86 f250 no fuel pressure with key on or cranking over but if i prime carb to start then fuel starts pumping i dont know if there is a safety on this model that only lets pump run if oil pressure is present some cars will only pump for about one second to prime system then will pump normal after engine starts
patpaolo is offline   Reply With Quote
Old 01-20-2005, 08:59 AM   #9
charman420
Problem fixed
I finally fixed the problem. A bad ground going to the EEC, which was disallowing the relays to kick over with a low 10.5 volts. Jumped the EEC ground to a good source and the pig fired up!
Bookmarks
Google
Web AF
