Changing Headlight Bulbs..saulster 12-30-2004, 09:07 PM How do I replace the headlights on my 1998 Honda Civc EX? thanks Chris brad5819 01-05-2005, 12:30 AM First disconnect the wire coming out of the existing bubl. There should be a ring around the existing headlight. This ring needs to be turned. Once the ring is turned the old bulb should just pull right out. When installing the new bulb, remember not to touch the glass part of the bulb. install the bulb the opposite way you took the old one out. Turn the rign the opposite direction and then connect the headlight wire Automotive Network, Inc., Copyright ©2012
