Re: 1998 Lumona ABS master cylinder
You can take the whole unit off (cyl. and ABS motor assy) and swap it out for a new/rebuilt kit, or you can just take it to a shop and let them do all the work. Don't seperate the motor pack from the cylinder yourself unless you got a scan tool and know how to relieve the tension. You can put a non ABS cylinder on, however you lose ABS and your light will be on constantly, and you'll have to revert to pumping if you slip.
