94 deville heater problems cold on left & hot on right side ????acewelderman 12-30-2004, 12:57 PM Heater blows equal amounts of air on both sides, but passenger side is hot and driver side is cold. This car doesn't have dual climate control. The temperature control is set on 90... :shakehead Thanks LARRY LARSON 01-14-2005, 10:07 AM Your Heater Core Is Blocked. Changed Mine Yesterday. 1995 Deville. Same Exact Symptoms. Paid $48.00 For Core At A Discount Store. Also Changed Thermostat.instant Success. acewelderman 01-15-2005, 07:29 PM I wondnt think it could be the core !!But if same symptoms it will be worth a try.Was it a hard install??? strmn94 01-15-2005, 10:57 PM I wondnt think it could be the core !!But if same symptoms it will be worth a try.Was it a hard install??? just did mine. it does take a little time, and you have to look at every way possible to get the parts back in. but it wasn't too bad. i had a pontiac that you had to cut a hole in the inner fender to get to a couple of bolts. the caddy was alot easier than that. Robt Prostek 02-12-2006, 07:17 PM The reason it is the heater core is that it has a upper and a lower portion the upper feeds the passenger seat and the lower feeds the drivers seat area. Do it yourself it cost me 350.00 at garage xtreme barton 02-12-2006, 07:58 PM you can look on autozone for repair instructions.. im almost certain they list it for your vehichle Automotive Network, Inc., Copyright ©2012
