Routing antenna throughXIntegraX 12-29-2004, 02:18 PM i was installing a new stereo for my ranger and im all finished except for the antenna. i cant seem to rout it from the outside right side of the car where its suppose to be. i did not have an antenna in this car before and i cant seem to find the right holes that go through the firewall and into the cab. how do i go about this? 2000mudder 12-30-2004, 08:28 PM you basically need to take off fender if you want to get to the factory holes. they are way in there. TheRangerOfDanger 12-31-2004, 07:24 PM you can also just fish it through one of the pre-existing holes in the fire wall and just have two wires going throught it (ie hole for hood release cable) - or you can just drill a small hole in the firewall (look what's one the other side b4 you drill...) and put a rubber bushing or o ring around the cut so that it wont scape one the wire and so that you can keep it somewhat waterproof Automotive Network, Inc., Copyright ©2012
