ABS Light..240ztt 03-06-2002, 04:35 PM just came on. Has anyone else had thiers come on. What does the code read or is it a multitude of things.. i.e. Joe needs to change his brake pads. I know when the brake light comes on it means Hey Joe add some brake fluid.:D flyg20 03-07-2002, 09:37 PM hey mine comes on all the time! but in 2 weeks, its going in the shop and theyre checking it out paradyme 03-07-2002, 09:44 PM Are you experiencing inclimate weather, IE. very cold weather, snow? Mine has gone on under these conditions. The sensor freezes up and when the car warms up it goes off. :flash: A380Driver 03-08-2002, 02:11 AM I just had to replace my ABS relays. They are in that little black box next the unit up front. After time these just wear out. What was happening to me is that even when I shut the car off, the ABS motor was still running. So I just pulled the ABS MTR fuse out to get that to stop till I could replace the relays. The dealer told me this was a common problem and they do wear out after a while. Check this out. I have yet to have a wheel speed sensor go bad. 240ztt 03-08-2002, 05:56 PM Originally posted by flyg20 hey mine comes on all the time! but in 2 weeks, its going in the shop and theyre checking it out Kewl. If it's no biggie let me know what they find out? Thanks 240ztt 03-08-2002, 06:00 PM Originally posted by paradyme Are you experiencing inclimate weather, IE. very cold weather, snow? Mine has gone on under these conditions. The sensor freezes up and when the car warms up it goes off. :flash: Unusally warm winter. Last few days in the 60-70s. But even today it was in the 70s and it came on. hmmm... 240ztt 03-08-2002, 06:26 PM Originally posted by A380Driver [B]I just had to replace my ABS relays. They are in that little black box next the unit up front. After time these just wear out. Interesting, What did those run you? How many are there? What was happening to me is that even when I shut the car off, the ABS motor was still running. So I just pulled the ABS MTR fuse out to get that to stop till I could replace the relays. My light just comes on when driving around normally. The dealer told me this was a common problem and they do wear out after a while. Check this out. huh....Really I have yet to have a wheel speed sensor go bad. I didn't know, are those common to go bad? Thanks :) 95_G20_P10 03-08-2002, 07:43 PM yeah u know what my abs motor was still running a few times afetr i shut teh car off. i was like what teh hell is that so i unplugged teh harnesses and then pluged it back in and everything was fine since then A380Driver 03-08-2002, 09:37 PM Originally posted by 240ztt Interesting, What did those run you? How many are there? My light just comes on when driving around normally. I didn't know, are those common to go bad? UHmmm i think the parts were $60ish a piece. theres two. When you shut off the car, see if there is any buzzing/motor running noise coming from the pax front side of the car...if so, then your ABS motor is still running. If you dont catch this soon and pull the ABS MTR fuse, you will burn out your motor. This is a costly replacement. I havent heard of anyone having a wheel speed sensor go bad yet, so im assuming they're pretty good. Some may freeze in cold conditions with slush up there tho I think. Your milage may vary. Automotive Network, Inc., Copyright ©2012
