97 Ford Ranger blows hot airmvanhuis 12-29-2004, 10:43 AM 97 Ranger will only blow hot air except when on Max A/C then cold air comes out. Would it be a relay in the selector unit or a broken blend door in the heater case? How would I fix these? ranger04 12-31-2004, 08:15 AM 97 Ranger will only blow hot air except when on Max A/C then cold air comes out. Would it be a relay in the selector unit or a broken blend door in the heater case? How would I fix these? I had a 97 Ranger with the exact same problem. It's the motor that operates the blend door. There is a plastic shaft that extends from the motor and when that breaks off the motor will still operate, but it won't turn the blend door. I had my mechanic fix mine and it was around $500.00!!! The part (new motor) is only like $70.00 or $80.00, but it's the labor that kills you because they have to take the entire dash out of the truck in order to get to it. Sorry for the bad news. I guess it's a common problem for that year :shakehead Good luck. gerg 01-04-2005, 11:09 AM I fixed my 98 Ranger blend door problem in about 40 minutes after reading this (http://www.ford-trucks.com/forums/showthread.php?t=24962). Good luck, Hope this helps. gerg mvanhuis 01-04-2005, 01:39 PM Thanks Gerg - Did the same thing and it is working great! Sorry Ranger04 you didn't see this thread. Thanks for the note. Automotive Network, Inc., Copyright ©2012
