rear window pisserMJTrippy 12-29-2004, 01:08 AM i got a 95 blazer 4x4 4D and my back window washer dont spary anymore i mean it used to and i just noticed that it dont spary anymore, is there a tank in the back of the blazer somewhere, my frount sparyers work and the wiper tank is full i just cant find the back tank or if there isnt one, what can i do?????? :werd: -Mike ricksza 12-29-2004, 06:01 AM Both front and rear washers use the same tank in the front of the vehicle the pumps are just at different levels. The rear is higher so it will go dry first. To test, swap the hoses from the front washer pump with the rear washer pump. When you turn on the front washers the rear window should get the squirt. If it still doesn't wet the window, check for a clogged washer nozzle, a disconnected hose under the rear compartment sill plate, or a disconnected hose in the tailgate. These are the most common. MJTrippy 12-30-2004, 01:46 AM how do i get to the hose's in the frount of the blazer????, and like where would they be Mounted on the tank? ricksza 12-30-2004, 06:02 AM They're both attached to their pumps on the side of the reservoir. punkrockdario 12-30-2004, 02:58 PM make sure you dont crack the lines. i did that. they get brittle crazy4nitro 12-31-2004, 08:37 AM or just top off the res. and try your pump again MJTrippy 12-31-2004, 01:00 PM okay i took off the rear pump, the outlet that the pump connects to has power,(tested with metter) but when you plug the pump back in nothing happens, i brought a brand new pump too, i dont get it....let me know whats the next step i should go to... thanks -Mike ricksza 12-31-2004, 02:58 PM The dark green wire has power when you hit the rear washers? Did you check the black wire for constant ground? Does the pump run and not squirt or not run at all? MJTrippy 01-01-2005, 04:11 PM no the pump doesnt even turn on, but the outlet that the pump connects to has power, then when you hook both together, it lose's its power and doesnt do anything ( and you know when you hold down the wash button on rear? the wiper goes back n froth really fast, it doesnt to that when you hold the down the button.... it just does normal speed ) werid ricksza 01-01-2005, 04:18 PM You don't want to connect both wires together. Hook a test light between the dark green wire and the black wire of the pump connector. Does it light when you push the button? If not, connect the test light between battery positive and the black wire. Does it light? If not, your ground for the pump is bad. The original ground goes to the radiator support, or you can run a new ground. Automotive Network, Inc., Copyright ©2012
