Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Cavalier
Old 12-28-2004, 07:45 PM   #1
savage8190
savage8190 Normal reputation
couple problems with an 86 cavy
hi everyone. just looking to solve a couple problems on a recently aquired beater. its an 86 cavy, 2.0, auto.
1)it stalls when it is put in gear, but only when its been driven for awhile and is hot, i would think this is the torque converter lock up solenoid right?
2)there is a weird noise coming from the front end, like a woop woop woop woop, and it gets faster as i accelerate, any ideas?
3)the engine ticks, sounds like lifters, again gets faster as i accelerate
4)my windshield defrost has very very little air coming out, and both that and my vent put out cold air, but the heater blows hot?
any help would be greatly appreciated
thanks
savage8190 is offline   Reply With Quote
Old 12-29-2004, 03:33 PM   #2
public
public's Avatar
public Normal reputation
Re: couple problems with an 86 cavy
1. Yes The TCC is the primary suspect. Also clean the IAC valve.
2. Sounds like a slightly warped rotor. New ones cost $20
3. These cars are known for valve noise. Easy to adjust, it just won't stay adjusted.
4. your baffle door is stuck. it is next to the heater core under the dash.
Good Luck.
Yes, I am retarded.
public is offline   Reply With Quote
Old 01-03-2005, 02:06 PM   #3
savage8190
Re: Re: couple problems with an 86 cavy
Good Luck.
ok first of all it was the TCC...runs fine now. Second i think you're right about the rotor.
Now I am just wondering how i go about making the adjustments to eliminate the valve noise. Also where exactly is the baffle door??
thanks
Old 01-05-2005, 03:18 PM   #4
public
public's Avatar
Valve noise on these cars is somewhat normal. You can tighten the rocker arms a little and that will help. Just don't over do it. As for the baffle door. I believe it is right next to the heater core. Under the dash in the very center, next to the fire wall.
Good luck.
Yes, I am retarded.
Old 01-05-2005, 05:16 PM   #5
jonjonwells
jonjonwells Normal reputation
Send a message via AIM to jonjonwells Send a message via MSN to jonjonwells
To fix the TCC problem, do I just replace the whole torque converter, or is it something seperate?
jonjonwells is offline   Reply With Quote
Old 01-05-2005, 08:18 PM   #6
public
public's Avatar
The repair more complex than that. You must remove tha valve body cover on the side of the tranny. This means you must remove the drivers side axle. The part is about $50 but because it is an '86 I would not worry about it. This will not hurt the car in any way. At most you can lose a little gas mileage. I have never noticed the MPG loss on mine.
Yes, I am retarded.
Bookmarks
Google
Web AF
