Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 12-28-2004, 07:56 AM   #1
fergmonster
fergmonster's Avatar
fergmonster Normal reputation
Send a message via MSN to fergmonster
1992 camry won't stay running
my brother in laws camry dies occasionally when he is driving it. It seems to me to be a fuel problem, because he can keep it running by pressing on the gas, but if he lets off it dies. If you let the car sit for a while, it will crank right back up and run like a dream..... any help?
fergmonster is offline   Reply With Quote
Old 12-28-2004, 11:32 AM   #2
jsinton
jsinton Normal reputation
Re: 1992 camry won't stay running
I'll bet your EGR valve is clogged. If it starts good, runs ok going down the highway, but at a light it runs like poo-poo and wants to cut out then that's the EGR. To check: Get a common hammer, locate the EGR, make it run bad, rap the EGR with the hammer (don't break it). You should be able to get the valve to unstick and it will idle like magic! Clean out the EGR with a coat hanger and carb cleaner or replace. Probably an air filter, and O2 sensor, and a tune up wouldn't hurt either.
jsinton is offline   Reply With Quote
Old 04-04-2005, 05:43 PM   #3
fergmonster
just an update: this car ran for a few months after cleaning egr valve. Now its running like Poo-Poo at stops AGAIN! i ordered an EGR valve today. should be here in a few days. The diagnostics gives me a MAP sensor code (31) but thats not it. I did the voltmeter check on the map sensor. checked out good. Thank god because its over 300 dollars!!!
Old 04-06-2005, 07:19 AM   #4
toughsticks87
toughsticks87 Normal reputation
Send a message via ICQ to toughsticks87 Send a message via AIM to toughsticks87 Send a message via MSN to toughsticks87 Send a message via Yahoo to toughsticks87
EGR went on my camry, after highway driving car would want to stall then eventually ran great. mine was so clogged with crap i just had to get a new one
toughsticks87 is offline   Reply With Quote
Old 04-06-2005, 07:23 AM   #5
fergmonster
if anybody needs a new throttle body, email me. i have one w/ IAC, and TPS sensors on it. really clean too!, since i thought it could be the problem. but it wasn't.
Bookmarks
Google
Web AF
