car smokes, doesnt overheat, leaks antifreeze when turned offbrandon_matt02 12-26-2004, 11:03 AM 95 5.2 v8... just recently when i turn my jeep off i noticed that it is smoking and im leaking antifreeze, but my temp isnt rising.... HELP? thoriason 12-28-2004, 12:28 PM Most likely you washed it when it was too cold outside or something to that effect. You prolly ruined the radiator, this is common in the jeeps for some reason when they get washed and it's too cold out. Check that with a local radiator shop before you try anything else. Hope this was of some help. Later gtmud 12-29-2004, 08:07 AM First look at your water pump, it might be leaking fluid from the "wheep" hole and it probably got on the exhaust from blowing back over the engine. Also look at your hoses and T-stat housing on the manifold, may have a small leak. TorinoGT69 12-29-2004, 08:49 AM gtmud is right those jeeps always leak from the thermostat and waterpump. Automotive Network, Inc., Copyright ©2012
