Coolant FlowNats 12-24-2004, 05:20 PM This past month my heat only works while I am giving the rodeo gas and moving. Standing still and giving it throttle doesn't work. Today when I arrived home I smelled antifreeze and my engine temp was high. Under the hood the radiator and reservior tank were both empty. I filled reservior tank and drove truck around the block. The temp gauge went past mid point again and I stopped and checked under the hood. I don't think the coolant was flowing. Is this a problem with my thermostat or water pump or something else? -Stan Ramblin Fever 12-24-2004, 06:13 PM Can you state what year, engine, miles you have? May help a lot. Nats 12-25-2004, 12:36 AM My engine is a 3.2L, V6, 4wheel drive. It is a 95 Rodeo. It has 135,000 miles. I love this truck. I just had front suspension replaced and installed a new alternator this past year. I bought it after the first owner, who only put 2,000 miles on it, bent the frame and the car was considered totaled. rodeo02 12-25-2004, 11:07 AM Sure sounds like a stuck thermostat. But a sudden loss of coolant w/out seeing it leak/spray out is a major concern. That could be a bad head gasket causing coolant to leak into the combustion chamber and crank case. If the truck runs good & there is no coolant coming out the exhaust, or in the engine oil, just try a new thermostat. G/luck Joel Automotive Network, Inc., Copyright ©2012
