Weight in bedA King 12-24-2004, 01:35 PM Should I Use Sand Or Sinder Blocks To Give Traction During Bad Road Conditions? If So, How Much Weight? fredjacksonsan 12-24-2004, 10:55 PM Sand; you can also use it for traction. Also, cinder blocks may roll or slide around on you. The amount depends on how bad the conditions are; I'm thinking you've got a 2wd. My brother said he'd shovel about 500 pounds of snow in his full size 2wd and didn't have a problem. You could probably get away with less, maybe 100 lbs over each tire, but trucks are different so a different amount may work best for you. BleedDodge 12-24-2004, 11:26 PM Around here people usually just keep their snowmobiles in the boxes of their trucks for traction, and so they have a way out if they become stuck somewhere. I've also seen sandbags, spare tires, things like that. fredjacksonsan 12-24-2004, 11:34 PM Snowmobile....that's the best idea I've heard. :D Dual purpose. indyram 12-25-2004, 12:20 AM I use my sled for the above stated reason. I also keep a couple of sand bags as well. Better idea that won't slide around and they work for putting under the tires. Automotive Network, Inc., Copyright ©2012
