Intake Manifold Gasketmarqis 12-23-2004, 10:04 PM Has anyone had a problem with their intake manifold gasket. Mine some how has blown. What causes this and what gaskets do i need? The upper or the lower or both.And what else do I need to replace. dwalmop 12-24-2004, 12:32 PM Yeah, I think everyone with a 3.1 or 3.4 has had to replace their intake gasket. The combination of being a terrible design and the expansion/contraction of the intake and heads is what makes them go bad. You should be able to purchase a kit that will have everything in it you need to replace, such as o-rings for the injectors and a TB gasket, etc. coolbreezzz 12-29-2004, 12:21 AM Has anyone had a problem with their intake manifold gasket. Mine some how has blown. What causes this and what gaskets do i need? The upper or the lower or both.And what else do I need to replace. I just had a prob with my intake Gasket There are 2 kinds for 3.1 1 that is for pushrod guides and 1s without the push guided 1s are a bitch BUT you can CUT the gasket to go around the Push rods This Kit will come with upper and lower intake gasket Cost $35.00 @ Advanced auto PS CAREFULL WITH THE GAS LINE WIEN YOU REMOVE IT DONT LOSE THE RUBBER SEAL bud36light 12-30-2004, 12:38 AM real common prob with both motors. 3.4 is really delicate. Just follow all the instructions closely when replacing. Automotive Network, Inc., Copyright ©2012
