SuperCharger Oil questionMIGTPGUY 12-23-2004, 03:37 PM i know kid or larry can help me on this. My neighbor is a master certified mechanic and also builds his own hotrods. He is around 50 years old. I had him come over and help me with my PCM install and T-stat as well as headlights the other day. He seemed to know what he was doing, but we had a lil debate. He is not a grand prix enthusiast like us. Somehow durring our talk about what kind of matainance i was gunna do to the car (flush and fill, oil change etc etc.) I brought up that with 100k miles and just recieving the car myself about 2 weeks ago, i was about to change the supercharger oil. He told me that i didn't need to and that the oil for the supercharger is fed through the engine oil itself. He was saying that the oil the lubes the pistons and everything also flows through and does its job on the S/C. I told him that GM makes an OEM supercharger oil. He was being a lil stubborn about it. Im just wondering if he has any truth to what he said. Im still going to take it to a dealership and have the S/C Oil changed kustomkid54 12-23-2004, 04:18 PM Tell your friend to keep working on old cars. The oil in the supercharger SHOULD be changed. It is not feed thru the engine oil or any other place else. Any oil in an enclosed area with the wear and tear that a supercharger goes thru will break down. Here is how you do it. http://www3.sympatico.ca/aepa/blowerinstall.html Enjoy Merry Christmas http://img.photobucket.com/albums/v425/kustomkid54/HappyHolidays.jpg carnutcass 12-23-2004, 05:37 PM He's probably thinking of the earlier (3800 Series I) supercharged 3.8 engines. Those superchargers ARE lubed by oil from the engine's crankcase. Just show him the Maintenance Schedule portion of your owner's manual. Every 30,000 baby! Forget the dealer, do it yourself. It only takes about 10 minutes. ericvrose 12-23-2004, 05:47 PM And when you do it, make sure you are wearing a gas mask! :iceslolan kustomkid54 12-23-2004, 06:32 PM Only if you have bean for Christmas. http://img.photobucket.com/albums/v425/kustomkid54/logo9.jpg MIGTPGUY 12-23-2004, 07:50 PM i smell something burning tonight, im afraid my supercharger is worn or damaged.... cuz i have 100k and i know the 2 people who had it before me and i dont think the oil has been changed at all. Should i be worried bad or just concerned lol. And if the oil in the SC is broken down and it is the two gears in the nose of the SC that are burning up, how hard and expensive are they to replace. Like i said, im 80% sure that the SC oil was never changed, since the car belonged to my friends mom before i got it. BTW there are no maintanance records in the glove box when i got the car. MIGTPGUY 12-23-2004, 08:33 PM o and Kid, that article on how to change the oil looked like just a picture of the kid gettting tho oil out. I dont have a syringe laying around to get it out and still have no idea if i juss pop that lil valve cover off to get to it. Im so worried that the gears in the nose drive are burnt out now. how much does a dealership charge to do it, way to much kustomkid54 12-23-2004, 09:36 PM You know I asked the dealer that. $50.00. Took it to the garage down the street. $30.00. Best way I found, an old waterbed pump. Ran a small hose off it, and let it do all the work. Here's another person's look at it; http://www.clubgp.com/cgi-asp/mods.asp?modid=13 http://img.photobucket.com/albums/v425/kustomkid54/HappyHolidays.jpg kustomkid54 12-23-2004, 09:38 PM And by the way, I maybe old, but my car is really fast. http://img.photobucket.com/albums/v425/kustomkid54/1998PontiacGrandPrixGTP004.jpg BIG-L 12-23-2004, 09:48 PM I dont have a syringe laying around to get it out and still have no idea if i juss pop that lil valve cover off to get to it. This is my revised version from clubGP :biggrin: What ive used for the past 6 yrs is an old spray bottle and some fish tank hose. Parts: You will need two bottles of GM supercharger oil, GM p/n: 12345982 Tools: Old Spray bottle w/pump Short fish tank hose about 12" long - needs to fit over the end of spray pump,and the other end in the s/c housing. 3/16 Allen wrench NOTE: Make sure that your engine is cool before starting this and is on level ground! 1.You can first start by removing the cover.Remove the center nut and set in a safe place,then lift up the cover and tip it back to release from the rear bracket. 2.Next remove the 3/16 allen head plug and set aside with the cover nut. 3.Insert the tube that's attached to the spray pump into the hole of the S/C housing,and pump out as much oil as you can inside the housing into the old spray bottle.This may have to be done a few times moving the hose around,to remove as much of the oil that you can. Dispose of your old/used oil with your old motor oil in an environmentally SAFE manner. 4.Add the new oil until it fills the snout to the bottom of the threads. It will take almost two bottles. Be careful to NOT overfill! 5.Screw the plug back in and do not over torque. Now you have just done an oil change on the SC. how much does a dealership charge to do it, way to much They wount touch it,but they will be glad to sell you a new SC :wink: i smell something burning tonight, im afraid my supercharger is worn or damaged I bet your smelling oil from a bad valve cover gasket......been there and done that :lol: And if the oil in the SC is broken down and it is the two gears in the nose of the SC that are burning up Ive never heard of a problem with those grears,but we do have a problem with the rattling of a bad SC coupler ~Larry~ MIGTPGUY 12-24-2004, 01:56 AM no noise, just smell. Big L, as far as mechanical terminology, im illiterate. When it comes to engines im more of a point and do, picture book kind of guy, so what is the Valve gasket. Im assuming there is mroe then one. Talking about engine or SC here. and could a dummy like me look at it and tell if there is a bad valve if i know what im looking for, or is this a mechanic's job? ericvrose 12-24-2004, 12:03 PM The valve cover...the cap where you pour your oil into the engine screws onto the valve cover. There is that one and another on the other side of the engine. There is a gasket between them and the engine. Alot of times that gasket starts leaking oil and sometimes you can see it pudling around the bolts that hold the valve cover down. If thats happening you will smell the oil burning. I dont think you would want to try this repair. The back one is hard to get to. MIGTPGUY 12-24-2004, 12:30 PM i notice oil , not puddling , but i notice some oil by the engine right by the headers.. MIGTPGUY 12-24-2004, 12:34 PM BTW Eric V Rose, are you by any chance from michigan.... this is gunna be so weird, but i have a buddy named Adam Rose and he has a cousin named Eric V Rose.... MIGTPGUY 12-24-2004, 12:36 PM and if this gasket is leaking, on a scale of 1-10, how big of a problem is this, and how much will it cost to repair, i have a buddy who is a mechanic, so exclude the hefty labor charge if there is one, doesn't sound to serious to me though.. ericvrose 12-24-2004, 12:46 PM That is weird. No, I'm in Las Vegas. And the seriousness of the leak problem depends on how much oil your loosing. Check your oil level and see whats up. It really isnt a big deal to fix. It's just very time consuming. The front one is relatively easy. The back one, you have to move alot of stuff out of the way to get to it. You basically cant even see the back one until you get all the hoses and brackets out of there. And when I did mine I went ahead and changed spark plugs also. That was alot easier with all the junk out of the way. You can get the gaskets at any auto parts store under $20. chrislanier 12-24-2004, 02:11 PM Does anyone have an idea on what it costs to get a case learn done at the dealer? MIGTPGUY 12-24-2004, 04:11 PM Chris, iunno your situation, but i do know that if you have ANYONE that is a buddy of yours that does any work on cars, or is a mechanic, chances are they have a TECH II scanner module and can do it. I know a couple people that have em. Fuck a dealership, i can give you a numerical value, but i know it is gunna be way to much. since they cahrge 75-100 for a full computer diagnostics on your car, im guessing a CASE learn would be anywhere from 20-50$, like i said, i have no idea. juss guestimating kustomkid54 12-24-2004, 06:40 PM Guy, A dealer won't do it. As a matter of fact, If you take a reprogramed PCM (in your car) to them, they will reprogram back to stock. The new Snap-On will also do it. Cass had an idea, I know it doesn't happen too many times. He said try some body shops. They have to be able to do it. The guy that works on my car bought the new Snap-on when he found out how easy it was. He charged me $30.00. Gas mileage went up by 3 MPG. Good luck http://img.photobucket.com/albums/v425/kustomkid54/HappyHolidays.jpg MIGTPGUY 12-24-2004, 07:43 PM Kid, I have a 97 GTP, just got a new INTENSE PCM, i swapped the KR module out of my stock PCM into the INTENSE, i read a bunch of places that a CASE Learn is not required for a 97 GP. But im wondering if it would help me out at all. Should i still get one done. My buddy has a Snap-On scanner, dont know the model or how updated it is, prolly can do a CASE learn. woulldn't cost me shit. Should i do this? BIG-L 12-24-2004, 08:13 PM dont know the model or how updated it is, prolly can do a CASE learn. woulldn't cost me shit. Should i do this? Sorry not kid,but if its free what the hell,it wount hurt anything. ~Larry~ kustomkid54 12-24-2004, 08:51 PM See I told you Larry always has the right answer. http://img.photobucket.com/albums/v425/kustomkid54/1998PontiacGrandPrixGTP004.jpg MIGTPGUY 12-24-2004, 09:23 PM Big-L..............your my hero.................. kustomkid54 12-24-2004, 09:29 PM It's the red "S" on his chest, right? http://img.photobucket.com/albums/v425/kustomkid54/santaanim250.gif MIGTPGUY 12-25-2004, 10:53 AM Big-L and his sidekick KUUUSSSTOM KIIIIID haha ;) merrrry christmas... kustomkid54 12-25-2004, 11:05 AM But, with the red paint, Larry's car is set for Christmas. Merry Merry http://img.photobucket.com/albums/v425/kustomkid54/HappyHolidays.jpg birchrj 01-26-2005, 07:17 PM ~Larry~ [I've never heard of a problem with those grears,but we do have a problem with the rattling of a bad SC coupler] Where can someone purchase the SC coupler? I have a 1994 Buick Park Ave Ultra that has a SC that rattles. I have looked all over for info on bearings and couplers but have come up empty so far. Any info would be appreciated. Thx. BIG-L 01-26-2005, 07:45 PM This is for 90 to present Eaton supercharger ~Larry~ Click here for coupler (http://www.zzperformance.com/zzp/products/engine/eaton_snout_rebuild_kit.htm) Here for snout rebuild kit (http://www.zzperformance.com/zzp/products/engine/eaton_snout_rebuild_kit.htm) kustomkid54 01-26-2005, 07:58 PM Coupler a lone; But the kit is better price. http://www.zzperformance.com/zzp/products/eaton_sc_coupler.htm http://img.photobucket.com/albums/v425/kustomkid54/p0000000138.jpg Automotive Network, Inc., Copyright ©2012
