Shocks--Best ones for Tahoe?
coopnhtown
12-23-2004, 08:46 AM
I have a 98 4X4 Tahoe. You know how heavy Tahoe's are. What is a really good front shock?
bartlanz
12-24-2004, 12:49 AM
I have the rancho 5000s i like the way they ride, but it is very trucky.
95tahoe4x4
12-26-2004, 02:18 AM
KYB MONO MAX, best thing I did for my tahoe for ride and control, plus they do not beat the s&^* out of you like the RANCHOS do.
Kt
glenncof
12-29-2004, 08:19 PM
Rancho 5000 front/back. I recently did the backs at 113K miles. I was "shocked" when I pulled out Bilstiens (factory). If I knew, I probably would have NOT replaced them. Now I glad I did ... nice tight ride. Even the wife commented about tighter steering response.
$80 for pair at Kragen online. Sure beats the $200 Bilstein I just put on Porsche. Yes, I did check to see if Rancho made ones for the Porsche...
glenncof
12-29-2004, 08:20 PM
$80 for pair at Kragen online. Sure beats the $200 Bilstein I just put on Porsche. Yes, I did check to see if Rancho made ones for the Porsche...(no).
pinnacle
12-30-2004, 07:14 AM
Anyone try Monroe "Reflex" shocks?
pinnacle
12-30-2004, 07:16 AM
Anyone try Monroe "Reflex" shocks? I have a 2002 Yukon and want to upgrade the front and back shocks. The back factory self-adjusting squeek and the front seem to allow a lot the body roll while cornering.
pinnacle
12-30-2004, 07:22 AM
Has anyone tried the Monroe "Reflex" shocks. I have a 2002 and want to upgrade to a good shock for road use. I want the shock to be smooth but keep the body from rolling in the corners.
rrousou
12-30-2004, 11:11 PM
Remember when you first got that unit new. It rode nice and smooth and handled nice..Thats one of the reasons you bought it. There's your answer.....factory OEM shocks. I made the mistake of getting after market shocks once and ended up with a "lumber wagon". Wasn't long after I shelled out the extra bucks for the original equipment. Thats' my two cents on the subject for all it's worth.
95tahoe4x4
01-02-2005, 12:29 AM
Like I Said Before *kyb Mono Max* Enuff Said
If You Need To Stay In The Budget The Reflex Is A Good Shock
The Rancho 5000's Are Good, If You Are Looking For An Off Road Shock, For The All Around, Go With Kyb Or Reflex.
Kt
TGARST
01-10-2005, 07:57 PM
I put them on my 03 Yukon the originals had 45K, seem to be a little softer in rear. The size of the reflex was smaller than the OE's in the rear,, same up front. Tires are Mich. Cross Terains
Tim
oneheavyhorse
01-22-2005, 04:37 PM
Hey Pinnacle, have you tried the Reflexes yet? I have a 2002 Yukon and was considering putting Reflexes on it...My OEM's are mushy in the rear and I was thinking of changing all four out at once. I want a little more stiffness on cornering. I've also been thinking about changing sway bars but can't seem to find much on that except from those who raise or lower the ride height too.
debrey
02-09-2005, 02:57 AM
Rancho RSX- great control, good ride, a touch stiff, but a great overall solution which is also affordable. The OEM's from the dealer were way overpriced.
glenncof
02-09-2005, 11:05 AM
I can believe it. I replaced rears on 1997 Tahoe and found factory shocks were BILSTEIN (kinda skinny though compared to the Rancho 5000).
Bilsteins are expensive even discounted online (www.shox.com). My Bilstein HD rears on Porsche were about $200 while Rancho's for Tahoe were $80 (pr.) and basically same size.
Yes, I did check if Rancho made them for Porsche (no).
sprucegoose
02-11-2005, 11:19 PM
I found that Auto Zone sold the Bilsteins at a greatly reduced price compared to the OEM. I bought the Biltein HD's for about $58 a pair. I am very happy with them. The OEM Bilsteins were pretty tired at about 125K mi.
They did offer a Bilstein Comfort Ride also, about $8 more I think, but I was worried there would be too much body roll for a full loaded rig pulling a trailer. He did say those were probably a little closer to the OEM ride.
glenncof
02-12-2005, 12:03 AM
sprucegoose, good find. I now have AutoZone plugged into my parts search. For 1997 Tahoe it shows $59 each, I assume yr $58 was each also.
www.shox.com was most competitive for Bilsteins on my Porsche and AutoZone was really close.
sprucegoose
02-12-2005, 09:01 AM
Ooops... my bad! Thanks for correcting me. I knew my memory wasn't getting any better, but that's pretty bad. My excuse... it was almost 2 years ago now! :D
I just looked up my reciept and it was 54.99 each. Part number B46-2178 and B46-2179. Not sure which is front or rear...
tbayliss
02-12-2005, 02:46 PM
I have Edelbrock IAS on the front of my '99, original Bilsteins on the rear.
They made a noticable difference in handling, although a stiffer sway bar would probably be the best way to go for controlling body roll.
