Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Dodge > Caravan/Voyager
Old 12-22-2004, 01:19 AM   #1
msalda01
msalda01 Normal reputation
replacement remotes programming
Can anybody help with programming instructions for replace remote, I have a 1997 Town&Country and the original remote is not working,model fcc is GQ43VT7T and the canada is 1470 k1361, I would preccite any halep, thank you.
msalda01 is offline   Reply With Quote
Old 12-22-2004, 03:59 AM   #2
theFREAKnasty82
theFREAKnasty82's Avatar
theFREAKnasty82 Normal reputation
Re: replacement remotes programming
ebay is your best bet for finding and buying replacement remotes.
theFREAKnasty82 is offline   Reply With Quote
Old 12-22-2004, 09:35 AM   #3
walbern1
walbern1 Normal reputation
You can only program it if you have one working remote. If this is the only remote you have and it doesn't work you'll have to take it in to the dealership. Here are some instructions I found, I don't know what year they're for and not sure if they work but maybe someone can verify.
1. Locate the dark green program enable wire connected to pin #1 of the 16-way data link connector under the left side Of the Instrument panel.
2. Connect the program enable more terminal to a good ground.
3. Insert the key into the ignition and turn the ignition switch to the ON position. The power locks will cycle (Lock and Unlock) indicating that program mode has been entered.
4. Using the transmitter to be programmed, press either [LOCK] or [UNLOCK]. The power locks will cycle indicating the transmitter has been programmed successfully.
5. Repeat step 4 to program additional transmitter.
6. Disconnect the program enable wire from ground to exit program mode.
7. Turn the ignition to the OFF position and remove the key
2007 Murano SL AWD
2003 Grand Caravan Sport
If you're not livin on the edge you're takin up too much space!
walbern1 is offline   Reply With Quote
Old 03-25-2005, 08:35 PM   #4
msalda01
Re: Re: replacement remotes programming
I just got a 1996 Chrysler T/C and I have one working remote, does anybody have the program instructions for extra remotes?
Old 04-01-2005, 04:38 PM   #5
msalda01
Re: Re: Re: replacement remotes programming
"I HAVE AWORKING REMOTE" Does anybody have intructions to program extra remotes?
In case anybody might have the same problem I found how to program extra remotes if you have at least one remote working.
This will work for T/C 1996 to 2000
Get in the van and shut door close, put key in ignition to turn on, using programed FOB, press and hold unlock button for 5-10 seconds, after 5 seconds press panic button(both buttons are pressed now), release boths bottons at the same time, you should now hear a chime, now in 30 seconds press lock and unlock button at the same time until you hear a beep, remember you have only 30 seconds to program all your remotes.
Old 04-04-2005, 02:41 AM   #6
gomezsydney
gomezsydney Normal reputation
Send a message via AIM to gomezsydney
Hi..
any help with the s problem
i have a 1995 plymouth voyager..
help me programming a extra remote..
please.!
before any help.. Thank...
gomezsydney is offline   Reply With Quote
Old 04-27-2005, 09:47 PM   #7
bigwheel53
bigwheel53 Normal reputation
You Can Buy A New Remote On Ebay For 20$ And Follow The Instructions He Gives You.they Didnt Work For Me So I Went To The Dealer.cost Me 30$ To Program.better Than Spending 120$
bigwheel53 is offline   Reply With Quote
Old 07-26-2005, 11:31 PM   #8
bobbyz
bobbyz Normal reputation
Re: Re: replacement remotes programming causing electrical problems
walbern, I have a 1999 plymouth grand voyager. tried your suggested fix to program remotes. when i connected a ground wire to the dark green wire i got a little spark, tried to program the remotes, and it didn't work... later i realized that the spark took out my radio, and now the electric door locks don't work when the key is in the off position... could grounding the green wire on a this vehicle have caused this damage - i'm now wondering if i grounded the red wire by mistake, could that have caused this? i checked all the fuses in the engine compartment and under the dash and can't see any bad ones. i just hope i haven't done more damage than it was worth...
does anyone have any ideas what i should check...
bobbyz is offline   Reply With Quote
Old 07-27-2005, 10:20 AM   #9
Hellcatbyte
Hellcatbyte Normal reputation
Re: Re: Re: Re: replacement remotes programming
OK FELLAS
Here it is an extract from the owners manual for a 1997 Voyager:
To Program Transmitters:
This feature allows you to program transmitters in case
one is lost or an extra transmitter(s) is desired. Up to 4
transmitters can be programmed to your vehicle. To
program another transmitter follow these steps:
1. Turn ignition switch to the ON position and leave
vehicle in park.
2. Using a previously programmed transmitter, press the
unlock the UNLOCK button for 5 to 10 seconds. While the
UNLOCK button is being pressed, press the PANIC button
and release both buttons simultaneously. You will hear a
chime sound to signal you that programming on the new
transmitter(s) may occur.
3. Press and release any button on each transmitter,
including the previously programmed transmitter, you
wish to program (up to 4). You will hear a beep when a
transmitter has been successfully programmed in. You
will have 30 seconds to complete the programming of all
desired transmitters. A chime will sound when the 30
seconds is over, or if you turn the ignition switch off.
If you do not have a programmed transmitter, contact
your dealer for details.
Hellcatbyte is offline   Reply With Quote
Bookmarks
Google
Web AF
