'98 Intrepid has intermittent start problem
kegenes
12-22-2004, 01:19 AM
At times I will turn the ignition key on '98 Intrepid and get no start-up. Lights come on but no ignition. If I turn the key to auxiliary and back the gear shift to neutral (or anything else) then back to park and try the ignition again, it will work. Any idea what is going on? The same problem occurred with my '93 Intrepid.
theFREAKnasty82
12-22-2004, 03:05 AM
sounds like your transmission range sensor is acting up.
A. Souphound
12-22-2004, 08:33 AM
kegenes:
It could be in the Shift/Ignition Interlock, do you have a Column or Floor Shift model?
Alvin
kegenes
12-22-2004, 09:57 PM
kegenes:
Alvin
It is an automatic transmission with the optional 3 speed "manual". Gear shift is a center mounted console between the front seats. Is that "Column" or "Floor Shift"?
A. Souphound
12-23-2004, 08:24 AM
kegenes:
It's considered a floor shifter. There is a cable adjustment at the base of the shifter.
Your narrative indicates to me the adjustment is marginal, since you can repeat the process and it works. Sometimes we are a little too gentle in placing the shifter in 'Park' and this will occur. To adjust the cable requires removing the Shift lever, Center Console, and Steering Column covers. Unless this becomes a cronic problem I would leave it alone, and try being a little more positive in putting the shifter in Park.
Alvin
