Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Dodge > Caravan/Voyager
Old 12-21-2004, 07:51 PM   #1
jlohrer
jlohrer Normal reputation
Question 1990 caravan 3.3 coil pack
Hi all,
I have a 1990 caravan which has been running great up to about 2 months ago. One day it started running very rough - definitely down a couple cylinders. The check engine light came on so I pulled over and by the time I stoped it was running good again. I hooked it up to a computer and it had a code 43. About 2 weeks later it did the same thing. It then ran fine for about a month and yesterday it acted up again - this time it ran rough all the way home. I just hooked the computer up to it again and it has the code 43 - but is now running good again.
Is it possible for the coil pack to be acting up this way or is it more likely a wire between the coil and control module giving me trouble?
Any insight is greatly appreciated.
jlohrer is offline   Reply With Quote
Old 12-22-2004, 06:52 AM   #2
GTP Dad
Pontiac Guy
GTP Dad Normal reputation
Re: 1990 caravan 3.3 coil pack
Code 43 indicates several things. Primary coil voltage not acheived with max dwell time, cylinder misfire or problem in power module to logic module interface. I would change the plugs and wires before the coils. You probably have a wire going bad, if that is the case the coils won't be far behind. You may also want to change the plugs if they are getting old and look at each one. A wet plug will indicate where the problem may be occuring. The coil isn't that expensive so you can change them if you wish so all the work can be done at once.
GTP Dad is offline   Reply With Quote
Old 12-23-2004, 04:37 PM   #3
murph7727
murph7727 Normal reputation
I agree with everything that GTP Dad has said. Good luck with it. Keep us posted!
murph7727 is offline   Reply With Quote
Old 12-24-2004, 09:12 PM   #4
jlohrer
Well, wednesday night I put a new coil pack on...I thought the plugs/wires would be OK because I installed them about 13000 miles ago. Van ran great until this morning when it started acting up again. Tonight I tossed a set of plugs in and changed the wires (always a fun job with cyl. 1, 3, & 5).
Thanks for the suggestions.
Old 12-29-2004, 09:39 AM   #5
jlohrer
code 43
Well I have tried the coil pack, plugs, and wires. Runs good for a while then acts up. I then checked for any bad wiring and cleaned all my grounds - same thing, ran good for about 1/2 hour then running rough.
Can any other sensor cause a code 43? Perhaps a bad crank position sensor.
Jason
Bookmarks
Google
Web AF
