need to start my 1972 charger that been sitting for 15 yearsbondhelm 12-20-2004, 01:17 PM I need tip on started a 1972 charger with a 318 engine that I just purchase dagrck74 01-07-2005, 05:08 PM How much did you pay for the 318 truckin dude 02-16-2005, 10:54 PM change the oil and filter first. The old oil has a lot of acids and stuff from setting all those years. Try to locate a oil pump shaft for priming the oil system.You have to pull the distributor to use one of these.mark the rotor positon and pull the gear out. If you don't feel comfortable pulling the gear just pull the coil wire.This will enable you to spin the engine to get oil pressure up . Don't forget to pull the plugs and spray some penatrating or lubricating oil inside.Those rings and cylinders are going to be real dry by now. Hopefully they ran it out of gas, if notyou will have the residude leftover. When get ready to start it add fresh gas at the carb if you can.have fun don't get discouaged. 99grandgt 06-20-2005, 03:13 AM also, if everyhting checks out, dont start it, run a compression test to see if its good to crank over....there was an article about starting motors that sat for years, its in this months mopar muscle...on newstands. pick it up and get some tips Automotive Network, Inc., Copyright ©2012
