2003 Isuzu Rodeo engine miss
ahinch
12-20-2004, 12:36 PM
Purchased new, V-6 4WD, has had an engine miss when accelerating since new. Have been to 5 Isuzu service shops, one replaced the EGR valve at 3,000 miles, one cleaned the throttle body. Neither helped. Milage should be 18-22 mpg, getting 16-17. Dealerships seem to want to help, but cannot get a handle on it. Anyone have a similar problem, and if so, what was the fix.
amigo-2k
12-20-2004, 01:20 PM
http://www.geocities.com/endre_rl/isuzufaq.htm#faq5
Right now you should be getting about 16-20 MPG, thanks to winter gas.
rodeo02
12-20-2004, 04:13 PM
Are you getting a check engine light now? Were you getting one in the past? A real misfire will cause the CEL to *blink* & a code scanner will tell you exactly which cylinder is misfiring. Under what circumstances / conditions does it stumble? Our 2002 will occasionally stumble very slightly when taking off from a COLD startup. It does it once, then that's it. I never persued it 'cause it runs like a top otherwise (29Kmi now) Mileage in the high teens is very typical. The absolute best our '02 can ever get is 18-20mpg, steady hyway driving. Same with the 2003 in our family. For a stumble on every cold take-off, I would suspect a bad intake manifold gasket. Bad IMG's are real common.
G/luck
Joel
2eyefishclaw
12-21-2004, 11:24 PM
need more info
