Heated Seats in 2001 Ram
gunner328
12-20-2004, 08:11 AM
I have a 2001 Ram 1500 with heated leather seats. This morning when I turned on the drivers side, the light in the switch blinked, and it never heated up. Can anyone tell me what this means? Thanks for your help.
fredjacksonsan
12-20-2004, 04:45 PM
Check the fuse first, owner's manual second. The O.M. should tell you what the blinking light is.
rockindaddy
02-16-2005, 12:01 AM
have same problem checked fuses etc.more than likely its the heat element in the seat.mine would get extremely hot just before it crapped uot
rockindaddy
02-16-2005, 05:00 PM
there's one other thing you could check it may also be the heated seat relay in the drivers side fuse panel.it's about 6 bucks it's worth a shot.
oneholdone
12-06-2005, 03:52 PM
there's one other thing you could check it may also be the heated seat relay in the drivers side fuse panel.it's about 6 bucks it's worth a shot. I have a 2001 3500 with dual heated seats, if i turn on the passengers seat it goes on with no problem, but when i turn on the drivers side the light on the high heat blinks for 40 to 60 seconds then goes out without the seat heating up. I removed the dash cover and reversed the switch wires with the same result. you sad there is a relay in the fuse panel is it marked in any way?
