Rear gear lube changegovols 12-19-2004, 10:21 PM How hard is it to change the rear gear oil? What is needed and what should I replace it with. 1994 sierra 5.7 2wd leeder70 12-19-2004, 11:35 PM not hard at all man all you need for lube is 80/90 gear oil tinstar 12-28-2004, 02:32 PM If it is a Limited Slip diff. you will need a LS gear lube . leeder70 01-04-2005, 12:38 AM ls gear lube started in 99 had to check that out when i changed mine. chevy dealer said 99 and up Automotive Network, Inc., Copyright ©2012
