Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Dodge > Caravan/Voyager
Old 12-19-2004, 01:22 PM   #1
rbunch4468
rbunch4468 Normal reputation
Fan Speeds only Off/High
The fan in our 2001 Grand Caravan will only run full speed. Any other setting on the switch, and the fan turns off.
My suspicion is the switch. Has anyone else had this problem? How does the switch remove from the dash?
Thanks!
Rick Bunch
rbunch4468 is offline   Reply With Quote
Old 12-19-2004, 01:39 PM   #2
cbwilsha
cbwilsha Normal reputation
Re: Fan Speeds only Off/High
Bad switch is very unlikely. The Blower Motor Resistor has gone bad in one or more segments. In my 98 T&C, it was located on the firewall under the hood on the passenger side. On my 05 T&C, it is located on the firewall inside the cabin just behind the glove box. During the 6 years I had the 98 T&C, I had to replace the blower motor resistor 3 times.
Yours is probably located in one of the two places mentioned.
C.B.
cbwilsha is offline   Reply With Quote
Old 12-20-2004, 09:02 AM   #3
rbunch4468
Re: Re: Fan Speeds only Off/High
Thanks...I'll check it out this afternoon, and post back my findings.
C.B.
Old 01-01-2005, 04:59 PM   #4
Mr Mel
Mr Mel Normal reputation
Your problem is located behind the glove box and fixed in 5 minutes Resistor is gone bad just fixed my yesterday with a nut drive only as the only tool and it works fine
Mr Mel is offline   Reply With Quote
Old 01-02-2005, 11:44 PM   #5
HeadlessHorseman
HeadlessHorseman's Avatar
HeadlessHorseman Normal reputation
Send a message via AIM to HeadlessHorseman
Bad switch is very unlikely. The Blower Motor Resistor has gone bad in one or more segments. In my 98 T&C, it was located on the firewall under the hood on the passenger side. On my 05 T&C, it is located on the firewall inside the cabin just behind the glove box. During the 6 years I had the 98 T&C, I had to replace the blower motor resistor 3 times. Yours is probably located in one of the two places mentioned. C.B.
Totally agree... I am curious, what do you think it was that required such frequent replacement of the Resistor Block on your '98?
HeadlessHorseman is offline   Reply With Quote
Old 01-03-2005, 11:11 AM   #6
cbwilsha
Headless Horseman--I really don't have any idea why I had so many resistor failures. I didn't mention that the last time I changed it, the plug to the resistor was badly burned and had to be replaced also. I've since seen other references to burned, corroded or melted plugs.
C.B.
Old 01-03-2005, 01:33 PM   #7
HeadlessHorseman
Re: Re: Re: Fan Speeds only Off/High
C.B. - I too have heard a few stories of burned/ melted wires and connectors - some of which made it necessary to cut off the bad wire/connector and replace it with a new one. Yikes.
Old 02-26-2005, 12:57 PM   #8
rbunch4468
Well...That didn't take too long...Three months to get around to going to the dealership to get the part, and less than five minutes to install it!
Your advice was right on...The resistor block on this 2001 Caravan is behind the glove box.
Thanks!
Old 02-26-2005, 07:34 PM   #9
HeadlessHorseman
This might help:
http://www.automotiveforums.com/vbul...d.php?t=340871
Bookmarks
Google
Web AF
