Update: 1993 Taurus Won't Start at Operating Temp.papasmith 12-19-2004, 10:36 AM I wanted to update what I found out about the following problem in case anyone else had it. I had a strange problem with my 1993 Ford Taurus not starting after reaching operating temp. It would start cold but if the car was warm it wouldn't hit a lick sometimes. Thought it was the fuel cutoff switch, then the fuel pump but, finally, I discovered that it was the Body Control Computer. To see if you have the same problem, with the ignition on, rap the body control computer module located on the right side under the plastic flap that covers your radiator. It is about 4 inches square. If you had my problem, you should hear the fuel pump engaging. Another test is to spray some starter fluid into the intake beyond the air filter. If it hits then, your problem is fuel delivery and may be the Body Control Computer. Hope this helps someone. KimMG 12-20-2004, 01:12 PM Thank you. I find updates and solutions always helpful. Automotive Network, Inc., Copyright ©2012
