Vacum prob keeps car from runningBlueCivic83 12-19-2004, 10:29 AM OK i started a post earlier cauz i tought it was my map sensor i switched it eith a working sensor but car still wont stay running. I was told to seal the erg valve tube still nothing are there any other suggestions ? oh and its a 89 cherokee limeted 4.0l Saudade 12-19-2004, 11:20 AM What makes you so sure it's a vacuum problem? BlueCivic83 12-19-2004, 04:00 PM Ok i was told to block one of the pipes i blokcked the wrong one and the car would stay running but died when i lift my foot form the pedal . So to conclude: it'll idle for a while but if i touch the gz pedal it dies. But when i had blocked the wrong pipe it did'nt idle but stayed running when i pressed the gaz pedal 89ltd 12-19-2004, 05:57 PM send a pic of the line you plugged BlueCivic83 12-19-2004, 06:05 PM http://www.sakgenla.com/forum/uploads/post-20-1103404596.jpg the vacum line that goes to the map sensor goes to the botom hole and the one i blocked is the one on top it has mnothing going to it and it's open. The car used to work with it like that i dont know if it were'nt meant to be like that JDPascal 12-19-2004, 06:10 PM If you blocked the port on the other side of the map sensor from the vacuum line, that would make a problem as it needs to reference atmospheric pressure thru that port to let the computer know how to adjust the fuel delivery. JD BlueCivic83 12-19-2004, 09:40 PM ok tomorow i'm going to call the mekanics again but they were home on saterday and did'nt fix it BlueCivic83 12-21-2004, 08:10 PM fixed the prob they replaced my tps sensor. Automotive Network, Inc., Copyright ©2012
