Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Dodge > Caravan/Voyager
Old 12-18-2004, 05:50 PM   #1
nnyxmfan
nnyxmfan Normal reputation
brakes
92 grand voyager. just picked up today from girls fathers, drove bout thirty miles and when got home noticed hot brake smell.and when put into any gear would not move without hard gas. let it set for awhile (hour) and started back up put in gear without foot on brake and idle moved van forward and back. put foot on brake and off again, and idle wouldnt move van. jacked one front side then other at different times so one tire would be on the ground and put in gear and watched tires spin fine. once put foot on brake tire stopped ofcourse but took mins to spin again. both sides did this but pass sides took slightly longer
help, help me ronda!!
nnyxmfan is offline   Reply With Quote
Old 12-20-2004, 11:08 PM   #2
coryjl
coryjl Normal reputation
well sounds like you got some sticky calipers....try taking the calipers off and cleaning the slides up and check your rubber lines I have the inside of the rubber line crack and work like a check valve letting the fluid go in but not back out O.o....really only way to find that out is by tryn to compress the calipers with bleeder closed. hope this helps.
coryjl is offline   Reply With Quote
Bookmarks
Google
Web AF
