water coming from under dashmicky101 12-18-2004, 02:39 PM When it rains I get a small amount of water on my passenger floor mat. Under further investigation (removed glove box and plastic piece that covers air blower?) I found water sitting in depression of plastic piece that is below motor for blower. I bring in plastic piece to dry out as it has some foam on it I guess for sound proofing. The next day after work I start my car (it has rained lightly all day) turn on fan for defrost and a lot of water falls from under dash. So now I guess the water is coming in from where fan gets out side air supply. Any suggestions Thanks so much GTP Dad 12-21-2004, 06:45 AM Check the drain hole, it is probably clogged. Usually located on the passenger side of the firewall. You can open it by putting a piece of wire through the hole. Automotive Network, Inc., Copyright ©2012
