Ignition Timing
invisiongrafix
12-18-2004, 01:56 PM
Anyone know the timing for an 88 Cherokee, 4.0, 5 speed, 4 wheel drive?
Dale Aeppli
12-18-2004, 02:01 PM
Ignition is controled by the ignition control module and is not adjustable Dale jeepman600@aol.com
invisiongrafix
12-18-2004, 02:03 PM
What are the indications of a bad module?
89ltd
12-18-2004, 02:12 PM
the module gets info from the sync sensor in the distributer and from the crank sensor in the on the top of the trans bell housing driver's side. I would think if you had a bad module, you would have problems starting or stauling, I think I may have a bad one because it cranks over forever before starting. What type of problems are you having?
invisiongrafix
12-18-2004, 02:19 PM
I was originally looking to advance the timing a little so I could get a little more power going up the mountain to get home. This is where I still have an overheating prob.
89ltd
12-18-2004, 02:22 PM
is your electric fan coming on quick enough?
invisiongrafix
12-18-2004, 02:27 PM
Yes. The electric fan comes on around 200 degrees. The radiator has been replaced. The water pump has been replaced. The thermostat has been replaced with a 180 degree with an air bleed hole. The fan clutch has been replaced. The coolant reservoir and cap have been replaced. Just had the system "vaccuumed" to remove all possible air. That helped some around town but it still overheated coming up the mountain.
89ltd
12-18-2004, 02:38 PM
do you hear any pinging or knocking when going up the hill?
invisiongrafix
12-18-2004, 02:39 PM
Don't hear any.
89ltd
12-18-2004, 02:54 PM
You sure have things covered with all the new parts, how high is your gauge going, does it run hot on level ground as well, before I forget, this link will give you a factory shop manual for the 88, I use it for my 89, don't know if you have it yet.
http://www.lunghd.com/Downloads_and_Links/Downloads.htm
invisiongrafix
12-18-2004, 02:59 PM
Thank you.
The guage goes into the red. I pull over and wait for it to cool down and then I go again.
89ltd
12-18-2004, 03:09 PM
has the jeep always done this, I have bought bad therastats before, now I put them in water on the stove and heat them up before installing them to make double sure that they will open at the correct temp.
invisiongrafix
12-18-2004, 03:10 PM
Even ran it without the thermostat.
89ltd
12-18-2004, 03:30 PM
have you always had an over heating problem or did it start suddenly? Is there anything to indicate that you could have a blown head gasket? Was there anyother work done lately?
invisiongrafix
12-18-2004, 03:34 PM
Did a block check and it was OK. These things are the only things done.
I have to go down the hill now and I dread the thought of the drive back home.
89ltd
12-18-2004, 03:39 PM
one thing that will help in a bind is to turn your heater on full with blower on high, works like another rad, I 'm really lost with this one, I know of some one that had over heating problems resulting from dragging rear brakes causing the engine to work harder, maybe somebody else will have idea's. It is a very poorly designed cooling system to begin with. Some people have changed the whole system.
http://www.automotiveforums.com/vbulletin/showthread.php?t=206558
invisiongrafix
12-19-2004, 08:57 PM
The first couple of weeks I had the Jeep it ran a little warm but nothing like this. One day it boiled over, blew the coolant reservoir, and It's been running too hot since.
invisiongrafix
12-19-2004, 08:59 PM
My understanding is that the only reason to change the system is to eliminate the air lock problem. Well, I've had the system vaccuumed to remove all of the possible air.
