Help Wheel Sizes
iLLuCiv99
03-04-2002, 01:41 PM
Hey everyone whats up? Well, the next thing on my "to-do" list is rims. I wanna find out more about sizes and everything b4 I buy anything. I really dont know what all the numbers mean though. Like 4X100, 40mm whats that all about? What is offset? What other numbers do I need to know, to make sure certain rims fit my car? If a rim is 18X8 what size tires would I need to get? 215/35/18 ?? Confused! :confused:
j.fuggi
03-04-2002, 01:51 PM
4x100 is the bolt pattern. 4 = 4 lugs needed 100 = 100mm bolts.
tire size is as follows
205/40/17
205: width of tire so if it were 17x7 the 7 would be the width
40: 40 is the height of the sidewall
17: is the rim diameter that will fit into the tire.
offset is a little harder for me to explain. i need to use images for you. but the site that has them is blocked from my school.
iLLuCiv99
03-04-2002, 01:56 PM
Originally posted by j.fuggi
205/40/17
205, is that like a measurement in like mm or something? and 205 will fit the width 7"? what about 215. like whats the difference in using those sizes? will they fit the 7"? Does 205 only correspond to the 7" width?
j.fuggi
03-04-2002, 02:08 PM
205 is 7" in millimeters.
205 is only 7".
215 is 7.5"
225 is 8"
and it goes up from there 10mm is like 1/2" pretty much
iLLuCiv99
03-04-2002, 02:11 PM
Things are a little more clear now :rolleyes: :D Do you know any links where I can read about the offset and other important stuff?!?! :smoker2:
92AccordCoupe
03-04-2002, 03:55 PM
205-40/17:
205 in the overall tire width (sidewall to sidewall) in millimeters
40 is the apect ratio (the height of the sidewall), expressed as a % of the width
17 is the wheel diameter in inches
check out this page on the tire rack for more info... (http://www.tirerack.com/tires/tiretech/general/size.htm)
edit: again, check the tire rack for offset info... (http://www.tirerack.com/wheels/tech/offset.htm)
iLLuCiv99
03-04-2002, 04:26 PM
is there a page that shows proper offsets for different cars? I would at least like to know what mine is :D I have a EJ8; 99 Civic EX 4 dr
92AccordCoupe
03-04-2002, 04:35 PM
actually, the bolt pattern is the greatest distance between the bolts, measured in millimeters... check this out for more info... (http://www.tirerack.com/wheels/tech/boltpatt.htm)
92AccordCoupe
03-04-2002, 05:12 PM
i don't know of a page that shows proper/suggested wheel offsets. the tire rack has databases of info on what fits and what doesn't, so you could call them and ask what the suggested offset is for a given wheel width on your car.
j.fuggi
03-04-2002, 09:53 PM
oh, oops. sorry. but thatnks for postinf the tirerack site. i wanted to but couldn't from school.
and i measured my sidewall with a ruler. 4cm or 40mm so i figure it isnt percent? or is it?
92AccordCoupe
03-05-2002, 11:07 AM
no problem :)
the sidewall height is a percentage of your tire's width. so a 40-series tire has a sidewall height of 40% of its overall width.
for example, i have 205-50/16 tires. the width is 8.1 in and the sidewall height is 3.2 in.
