Caravan 2000-Passenger side power window.
Google
Web AF
Bacoman
12-17-2004, 10:30 PM
Mine won't respond at all. I have looked for a fuse and can not find it. Is there a fuse that I can check before I take the panel apart? Thanks
donnie59
08-08-2005, 09:08 PM
In my 98 Grand Caravan, the fuses are self resetting and located under the drivers seat - however - they are only serviceable by the dealer according to the owners manual. I read a post somewhere about the problem and gave the recommendation a try as I didn't know what else to do. Keep in mind that the window just stopped working - no sounds, no grinding, no motor sounds, nothing. It's almost as if it was unplugged. I took off the door panel and removed the electrical plug from the motor. I took off the motor cover and spun the armature around a bit. I put the cover on, reattached the electrical swithch, and put the door panel back on. It now works great. My .02
donnie59
08-08-2005, 09:17 PM
Now I remember the poster's name - phantastic1. His advice got my power window working again. Thanks phantastic1.....
Stretch58
08-08-2005, 11:07 PM
I assume you probably checked it but, is the "Lock" switch on the drivers side door turned off? If it is on, the passenger side window won't work.
Google
Web AF
