Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Dodge > Caravan/Voyager
Old 12-17-2004, 01:33 PM   #1
kajjun
kajjun Normal reputation
Send a message via AIM to kajjun
Fuel Pump
Does anyone know how to remove the fuel pump from tank of 1992 Caravan SE?
kajjun is offline   Reply With Quote
Old 12-17-2004, 02:12 PM   #2
murph7727
murph7727 Normal reputation
Re: Fuel Pump
if there is alot of gas in the tank cyphon it out with a hose. First there are two metal straps holding the tank in place. Use a ratchet and socket to remove one of the straps. Loosen the second strap, leaving enough tension to hold the tank up. Reach above the tank and unhook the wire connections. After unhooking them you can now remove the second strap. The tank should be ready to remove. Now you are looking at the top of the tank. Twist the fuel pump assembly and it should be able to remove. Be sure to take the gasket off as well and replace with a new one. This will help from condensation getting in. There is your fuel pump. I may have left out a couple steps but the overall directions are there. If your at all mechanically inclined then the smaller details should be common sense items. If not inclined write back with problems you may be experiencing and I can help you out. Have Fun!!
murph7727 is offline   Reply With Quote
Old 12-17-2004, 08:09 PM   #3
kajjun
Re: Re: Fuel Pump
Thanks. Finally got it out and fuel pump is shot. Cleaned tank out and bought another fuel pump. I didn't know this was such a job!!
Bookmarks
Google
Web AF
