2000 Chevy Silverado Intermittent starting problem
mpm51896
12-16-2004, 10:51 PM
I have a 6 cyl 2000 Chevy Silverado Extended cab with 114 k miles, I drive it daily about 50 miles per day. In the past 3 weeks I have broken down 3 times.
The first time the truck stalled after running for about 1.5 hours and would not start. I cranked over fine. After waiting about an hour it started. I took it to the dealer and they found nothing wrong.
Second time i drove it about 35 miles and turned it off about 15 minutes later it would not start. I had it towed to the dealer and when they looked at it the next morning it started and again they found nothing wrong.
Third time today after the dealer found nothing wrong, I drove about 25 miles, it started 3 times after stopping to do errand. right now it won't start again. I cranks over but just won't start. Any isea what may be cauing this? t
Greenblurr93
12-16-2004, 10:58 PM
As for your question, it sounds like an electrical problem, check wires to make sure none of them are grounding out causing a dead short.
Greenblurr93
12-16-2004, 11:01 PM
also sounds like your fuel filter needs replacing.. maybe sediment is in it and hen u first start it its all settled and the truck runs fine, but after it gets stirred up it starts to clog the fuel line and stall your truck... this happend in my nissan....
TheSilentChamber
Could bet electrical, but more than likely fuel problem, I'd take it to a differnt mechanic. Dealership people usually are your run of the mill tech school drop outs.
Catboy
12-17-2004, 10:03 AM
I believe that this is a malfunction in your passive security system. I had the same problem with my 2000 right after I bought it. Since it was under warrantee, I brought it into the dealer. They replaced the ignition key assembly (there is another name for it, I can't remember) and 60k miles later I haven't had a problem. I think that they might have rerouted a wire to prevent it from happening again. What happens is that the system suspects that there is no key inserted, but instead of cutting out the starter it just cuts out the ignition. After a certain period of time (I think about 15 minutes), the system resets itself. Tell the dealer to call Pape Chevrolet in South Portland, Maine and their competent mechanics should be able to explain it to them. I would be surprised that it is not a service bulletin, but sometimes these guys don't make the effort to look. I just talked to a friend of mine who is a GM service manager about the antilock brake problem with these vehicles and he said there was no s.b. on it. I found the bulletin number on line (probably at AF.com) in about 5 minutes. Anyway, I hope this helps your problem.
Josh
mpm51896
12-25-2004, 04:26 PM
I'm still having the intermittent starting problem.
The truck was in the shop for 3 days while they tried to recreate the problem, they have been unable to have the problem while it is the shop.
I have broken down three more times since and if I leave it where if dies and go back the next morning it starts fine.
They have replaced the distributor cap and rotor, wires, plugs and a sensor(not sure of which one).
They tested the fuel presure regulator and it is working correctly. the fuel pump was tested and the pressure is only 49 instead of 60. The mechanic says (because of the cost and the fact that I gave him a hard time about finding the real problem without just replacing expensive parts until it is finally fixed) he does not want to replace it unless it fails or he can get a code. The guy seems to be trying to fix it. he has spent a lot of time checking everything and has not charged me for the time. Any suggestions
NWChevyGuy
12-27-2004, 02:48 PM
My 2001 8.1 does the same thing. Anyone have anymore ideas?
