coolant leak from water inlet side
97 caravan 3.0 v6
It started out with a radiator leak(small).I let the car run for few weeks adding water every so often then everyday.
lately the leak was also coming from the lower hose connection to the engine block. so I decided to change the radiator and the "o"ring on that inlet.the radiator leak stopped but not the leak from the engine side of the inlet(driver side).I can't see exactly from where the water would be coming from.
Please help
