ECU fuse
gsr916
12-16-2004, 04:08 PM
where the hell is it? i can find one that says "FI E/M" its a 15 amp fuse. most ppl said it should be a 10 amp fuse that actually says "ECU."
whtteg
12-16-2004, 04:26 PM
It is fuse number 32, looking at the fuse block from the passenger side of the car, it is the 2nd one in on the left in the line of fuses, there should be a toatl of 4 fuses in a row, it should be a 7.5 amp fuse. The 15 amp fuse you are seeing is probably the PGMFI main relay fuse.
gsr916
12-16-2004, 06:00 PM
well the 15 amp one says FI E/M so definitely fuel injection, E/M = electronic management? the 2nd fuse on the left is a 7.5 amp fuse, but it says "backup, (radio)" and it is in a line with 5 fuses not 4. heh
gsr916
12-16-2004, 06:04 PM
#32 in my car is for front parking lights, taillights, and license plate lights lol, plus it is under the dash. #47, the 7.5 amp fuse 2nd from the left says that it is for clock, audio, ECM, TCM, and maintenance reminder it just doesnt say that on the cover... so i found it. thx
whtteg
12-16-2004, 10:03 PM
Hmm that's weird, in my car it is #32. And also I don't have a fuse #47 mine goes up to 46 but 44-46 are not used. Hmm I guess maybe the OBDII cars are different, I would not have thought so though. Hmm.
SiGNAL748
12-16-2004, 10:34 PM
Forget the numbers. Just look at the diagram, and pull whatever's the clock/radio fuse.
