1987 Civic No Heat!!! Please HELP!!!
ahmooresville
12-16-2004, 09:24 AM
OK, My 87 civic 1.5 carbed, only has warm air at best, won't even clear the windshield...
Car warms up normaly to normal operating temp
Both hoses to heater core seem to be getting hot (hot to touch)
Coolant level checked... OK Thermostat checked... open and closes
Blower motor operating normal...
All cables and doors open and close properly
I can hear a gurgling noise (sometimes) when the Temp lever is moved from cold to hot...
Any Ideas?????
Figori
12-16-2004, 05:56 PM
Might want to try to flush your system... Or check your fluid level. If there isn't enough fluid sometimes it can cause an air bubble that will keep fluid from getting to the right places. Just my :2cents:
ahmooresville
12-16-2004, 06:28 PM
Well i have checked the fluid level and it was good, however I wondered about air in the lins, however the bleeder valve seems to be frozen shut, and I'm afraid I'm going to snap it off... But that gurgling sound is why I think you might be right...
Any ideas of how I can bleed the cooling system, without useing the bleeder valve?...
mormilesthanne1
01-02-2005, 06:35 PM
this is a long shot but check your drivebelt tension for the water pump
