Re: Cavalier heater problems
Good Morning !
I believe that you have 2 separate problems. The first one about fan speed, there is a square box, about 2 inches by 2 inches under the glove compartment against the firewall in the bottom of the fan motor housing, this box has 4 resistors epoxied on the board. There is one resister for each speed on the fan motor setting, 2 of the resistors have burnt out. This is pretty common with the Cavalier, I will be replacing my second one in 2 years in the near future. If you are flexible, and have small tools, it can be replaced in a few minutes without have to take tooo much stuff apart.
The no heat after 35 miles an hour, you need to change the thermostat again. It is vary important that you buy one form the dealer or you get one with an extra heavy spring. NAPA has one THM 531090, works great.
I suffered the same issue, after replacing 4 thermostats I found out that there is a difference in the spring diameter. That is vary critical for these cars because of the water flow, the regular replacement thermostats with the softer springs don't hold the water as the engine picks up speed.
When you get the NAPA or the dealer one look closely at the spring.
Hope this helps
Take Care
Roy
