car ran out of gas, now it wont start
izzzyy76
12-15-2004, 06:01 PM
i have a 1993 acura integra. It recently ran out of gas and it wont re start anymore . I added gas , i changed the distributor cap and the rotor but im not getting a spark from my cables any idea what will fix this. the fuel pump i relly doubt cause i ccan smell the gas. it doesnt give a sprk from the cables i have no idea what to do.
dude4u
12-15-2004, 06:03 PM
u should really go to the nearest auto store and pick up a circuit tester to see if u have any eletrical problems but if that's not it check the fuel filter and injectors since u said it's not the fuel pump but check ur ground wires and everything as well
whtteg
12-15-2004, 07:03 PM
Go out side and turn the Ignition switch to the "ON" position, make sure it is quiet around you. Now do you hear the fuel pump turn on for about 3 seconds? If not then it could be bad.
Sha_kri
12-15-2004, 07:36 PM
I have a 1988 Integra. Had the same problem. Drove me nuts. Mechanics could not figure it out. Finally took it to a Honda/Acura specialty shop. They knew exactly what it was. I forget what it was, but its some problem unique to Acuras. --very hard to detect--. Cost like 500 bucks to fix it, but never had that problem again.
I did same thing, changed dist. cap, checked cables, blah blah blah.
You need to find your nearest Honda/Acura specialist. (Don't goto the dealer IMHO).
izzzyy76
12-15-2004, 11:24 PM
damn i was hoping somebody knew what was wrong the whole point of posting this problem was to save a lot of money . im sure the specialists would love to rip me off again just like in the past. with a couple of other things.
integrawhat
12-15-2004, 11:38 PM
if you dont want to go to a specialist buy a haynes or chilton manual and a circuit tester and you should ba able to figure it out on your own.
whtteg
12-16-2004, 12:03 AM
www.helminc.com (http://www.helminc.com) The only manual you should buy!
integrawhat
12-16-2004, 12:19 AM
omg that manual is $62.00 i like to have all the info i can but how much more info for 62 dollors does this manual have that the other two dont
whtteg
12-16-2004, 12:30 AM
A ton! I have a haynes and I have a chiltons and they are no where near as in depth as this manual. These are the same manuals that the Honda and Acura dealerships use in their shops. The others will work but this is by far the best.
integrawhat
12-16-2004, 12:36 AM
so your saying it is worth the money
whtteg
12-16-2004, 12:53 AM
IMO yes ;)
Here are a few pages I scanned for some people a while back.
http://bellsouthpwp.net/w/h/whtteg/clutch%20pedal%20adjustment.jpg
http://bellsouthpwp.net/w/h/whtteg/scan1.jpg
http://bellsouthpwp.net/w/h/whtteg/scan2.jpg
http://bellsouthpwp.net/w/h/whtteg/scan3.jpg
http://bellsouthpwp.net/w/h/whtteg/scan4.jpg
http://bellsouthpwp.net/w/h/whtteg/scan5.jpg
Those are just basic things though, I can scan some more pages and you can see the difference. I will post up some more tomorrow.
integrawhat
12-16-2004, 01:03 AM
does it go into detail on tranny internals, is it hard back and about how many pages. if you could hook me up with some internal tranny pics that would be awsome
genkichild
12-16-2004, 02:04 PM
I'll second that its a nice manual. It's what I use for my teg, and it's way better than the Chilton one I had for my old GTI. I'd send you some scans, but the book is at my mom's house.
whtteg
12-16-2004, 03:52 PM
What exactlyt are you wanting scans of? There are 50 pages on the Manual tranny alone, not including the differential. About 40 of those pages are the internals. Here is a expanded view of the mainshaft and countershaft and everything else thatis inside the manual tranny. The first pic is full size and the second is resized.
big (http://bellsouthpwp.net/w/h/whtteg/tranny_big.jpg)
small (http://bellsouthpwp.net/w/h/whtteg/tranny_small.jpg)
weilyan
01-10-2005, 01:03 AM
Is there power going through the car? I mean any lights? It might be the ignition coil. I had a similar problem about 4 months ago...the car won't turn at all. It's rather easy to change the coil.
Tano016
01-12-2005, 09:25 PM
http://www.hondahookup.com/manuals/ , try this link
