Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Honda > Civic > '01-'05 Civic
Old 12-15-2004, 05:31 PM   #1
scar0707
scar0707 Normal reputation
temp gauge not working right
hey whats up was wondering if i can get some info the other day i went for a drive in the cold weather and my temp gauge only moved to 1 tick obove cold was driving for 15min and then went on the highway and then it moved to the 3 tick but got to the stop light it went back down to 1 above cold heat was on full the whole time and was not very hot went to honda they said that the thermosat was open and closing that was not the problem any help would be great.
scar0707 is offline   Reply With Quote
Old 12-15-2004, 06:49 PM   #2
Beastiek2
Banned
Beastiek2's Avatar
Beastiek2 0
Send a message via AIM to Beastiek2 Send a message via MSN to Beastiek2
Re: temp gauge not working right
No codes are being thrown which means it is working (temp sensor). This could be a bad thermostat or maybeeeeeeeee the cluster is malfuncioning. Best thing to do is check ur thermostat housing reseat the wires. Check then. You could replace the thermostat which could be an easy fix. If you wanted to get technical you could get a resistance meter and check the sensor to make sure the resistance is changing as the engine gets hotter. This will mean bad sensor, if nothing changes on the multimeter but the car would be throwing codes as stated above. If Honda told you what the problem was how did you determine it to be false?
Beastiek2 is offline   Reply With Quote
Old 12-15-2004, 07:26 PM   #3
scar0707
all honda told me was that hey could not determin what the problem was the said that it was normal for the temp to drop while ideling.
but i have friends that have civics and theres don't do that. well i think im going to try and change the thermosate and see what happens. so how where can i get a resistance meter to check the sensor to make sure the resistance is changing as the engine gets hotter. and how do i check it do i just put it in the rad fluid? all i know that it is NOT normal for a car to take over 30min to get hot or if it gets hot at all
Old 12-16-2004, 06:01 PM   #4
Beastiek2
Banned
Beastiek2's Avatar
Beastiek2 0
Connect to the temp sensor wire its a 2 lead wire.
Old 12-17-2004, 11:24 AM   #5
scar0707
thanks for the feedback i see where the temp sensor is but can you tell me where to get a resistance meter to check it so when i get one i just hook it up to the sensor and check to see if the temp is changing and if it is then thats not the problem?
Bookmarks
Google
Web AF
