Friend has trouble as welldude4u 12-15-2004, 05:19 PM Ok my friend has an integra same as me 91 and it's an ls special not like it matters but what does matter is this. he says the clutch sticks in each year and doesn't like to shift or won't shift and he says if ur lucky and make it thru the gears it will get stuck in 5th gear or in reverse. He says if u put it in first gear it sounds like it's in 4th gear cause the acceleration is slow. it might have a timing problem but i'll further the info some more if i get it. whtteg 12-15-2004, 07:16 PM Are you saying that it won't come out of gear? Does the car go into neutral when the clutch is pressed in? Have you tried checking the clutch cable to see if it needs to be tightened up? Need some more information, be as specific as you can. project91integra 12-15-2004, 08:46 PM Are you saying that it won't come out of gear? Does the car go into neutral when the clutch is pressed in? Have you tried checking the clutch cable to see if it needs to be tightened up? Need some more information, be as specific as you can. im the person he was talking about w/ the integra.. ok heres the deal.. i was taking my g/f to the mall to shop and shit, and i put the car in reverse i had no problem at first. it was wen i tried to get it out of gear. like put it into 1st. but the shifter wouldn't move. i was banging it. pullin on it. and just doing everything possible to get it out of reverse. finally when i managed to get it into gear the speed was like really slow sounded like i was about to stall out. i didn't know what to do. so i had parked it in an open parking lot and left it there. at first i thought it was the clutch cable but it wasn't. i had replaced that about 6 months prior. because the same problem happened to me b4. i have heard of several possiblities of what it could be but they don't know. i really do need some help.. my car has over 150,000 miles on it. so maybe it could be clutch. please help me... oh yea it does go into neutral fine. if the car isn't running it will go only thro the four gears. but once u try 5th and reverse it gets stuck. integrawhat 12-16-2004, 12:13 AM id have to say your clutch is blown sounds like the same thing mine does when its time for a new one whtteg 12-16-2004, 12:32 AM But you only have problems when you go into 5th or reverse? I am thinking it would be something internal on the tranny if it has no problems in any other gear. integralover 12-16-2004, 12:33 AM agree. sounds like a clutch integrawhat 12-16-2004, 12:40 AM But you only have problems when you go into 5th or reverse? I am thinking it would be something internal on the tranny if it has no problems in any other gear. confused. are you talking about me or project whtteg 12-16-2004, 12:42 AM confused. are you talking about me or project Project ;) integrawhat 12-16-2004, 12:55 AM ok is his prob only in fifth or all gears i thought he said all but if its only fifth and rev its probably internal like you said whtteg 12-16-2004, 12:57 AM ... oh yea it does go into neutral fine. if the car isn't running it will go only thro the four gears. but once u try 5th and reverse it gets stuck. Well I am not 100% sure he needs to be a little more clear. project91integra 12-16-2004, 01:43 PM id have to say your clutch is blown sounds like the same thing mine does when its time for a new one now if i were to buy the clutch would there be anything else that i would have to buy. i know the release fork don't come with. but if the clutch were to be replaced would it run like normal whtteg 12-16-2004, 03:44 PM now if i were to buy the clutch would there be anything else that i would have to buy. i know the release fork don't come with. but if the clutch were to be replaced would it run like normal You should read the posts and answer some questions before we can determine anything. Read and aswer the questions that we are unsure about above. project91integra 12-16-2004, 04:09 PM You should read the posts and answer some questions before we can determine anything. Read and aswer the questions that we are unsure about above. wat other questions do u want to know bout the car so u can come to a finall conclusion bout the clutch ..? whtteg 12-16-2004, 04:14 PM Read post 9 and 10 and give us a clear answer. It is hard enough to try and diagnose a problem over the internet let alone not get clarification. kornflakes28546 12-16-2004, 05:49 PM this thread is crazy dude4u 12-17-2004, 12:17 PM ok is his prob only in fifth or all gears i thought he said all but if its only fifth and rev its probably internal like you said He said it's all gears. He said that if the car is sitting still not running ok. Just like ur playin with the clutch with the car off. he said u can put it into all the gears 1,2,3,4 with ease like a normal clutch but he said as soon as u put it in 5th or reverse it gets stuck and it's hard to put it into and pull it out of gear. so basicually it gives ease when ur putting it into all the gears but as soon as u put it into 5th or reverse it gives resistance when going into and coming out of gear. If you have any other questions. my aol screen name is vacacow and my AIM is possesedantalope. They are linked to my phone so if u contact me that way i'll get back to your replys sooner. thanks Automotive Network, Inc., Copyright ©2012
