Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Nissan > 240SX/Silvia/200SX(RWD)/Gazelle/180SX
Old 12-15-2004, 01:32 PM   #1
KA-ALLTHAWAY
KA-ALLTHAWAY Normal reputation
Do They Make A 2.6l Stroker Kit For The Ka24e
I Was Told They Do But I Havent Been Able To Find One. If There Is Would Somebody Be Able To Tell Me Where I Could Get Such A Thing
KA-ALLTHAWAY is offline   Reply With Quote
Old 12-15-2004, 01:35 PM   #2
Chuki_breath
Chuki_breath Normal reputation
Re: Do They Make A 2.6l Stroker Kit For The Ka24e
never heard of a stroker kit for E engines. Sure it wasnt custom???
Chuki_breath is offline   Reply With Quote
Old 12-15-2004, 01:44 PM   #3
KA-ALLTHAWAY
Re: Re: Do They Make A 2.6l Stroker Kit For The Ka24e
I SWEAR I SEEN IT IN IMPORT TUNER MAG BUT I COULD BE WRONG
Old 12-15-2004, 02:38 PM   #4
R.W.240
Banned
R.W.240's Avatar
R.W.240 Normal reputation
have you ever seen that Chris Rock Show where he's talking about the Anklet on the Fat chick. "Anklets holdin on for dear life like arrgg!!"
yeah...
because that will be what the rods are doing on a 2.6 KA at 6000RPM
R.W.240 is offline   Reply With Quote
Old 12-15-2004, 04:54 PM   #5
GSR
GSR
Send a message via AIM to GSR
boost>displacement
looking for a 95+ 240sx in/near D F Dub area
GSR is offline   Reply With Quote
Old 12-15-2004, 05:34 PM   #6
nissanfanatic
240SX Guy
nissanfanatic Normal reputation
Send a message via ICQ to nissanfanatic Send a message via AIM to nissanfanatic Send a message via MSN to nissanfanatic Send a message via Yahoo to nissanfanatic
Boost is displacement. The KA does not need any more stroke. You are going to be looking at some serious bucks for something like that. Try calling some shops and companies such as Crower, phatka-t, boostdesigns, and basically any shop you can think of. Crower would be a good company to call because they are starting to take interest in the KA. Ivan at Phatka-t would also be someone to try. He is really smart, has some really good connections, and has some of the baddest cars in the US.
www.phatka-t.com
www.boostdesigns.com
-Cory
1992 Nissan 240sx KA24DE-Turbo: The Showcar
Stock internals. Daily driven.
12.6@122mph
496whp/436wtq at 25psi
nissanfanatic is offline   Reply With Quote
Old 12-15-2004, 06:31 PM   #7
GSR
GSR
huh? boost is displacement? and i always thought displacement was defined as the area from bdc to tdc, whereas boost was simply more efficiency out of the given displacement
Old 12-15-2004, 06:55 PM   #8
nissanfanatic
240SX Guy
Boost is air being forced through the engine. You are increasing the density of the air entering the engine so more air is being displaced. Think of it as building blocks. The air entering the engine while it is naturally asperated is like a unorganized pile of blocks. The air entering the engine via forced induction is like a pile of blocks stacked neatly. You can fit more neatly stacked blocks in a given area than you can unstacked blocks. Get it? More air is being dislplaced.
-Cory
12.6@122mph
Old 12-15-2004, 08:56 PM   #9
D-Bo
D-Bo's Avatar
D-Bo Normal reputation
instead of air being sucked into the engine, its being pushed
Originally Posted by iVteC_PoWeR
to me when i really look at it hondas just too expensive and theres not much power even after you spend loads of money...
http://www.cardomain.com/id/dbo240
***LOOKING FOR A COUPE, ENGINE IS NOT AN ISSUE***
D-Bo is offline   Reply With Quote
Old 12-15-2004, 09:43 PM   #10
SR20DETpower
Banned
SR20DETpower Normal reputation
Send a message via AIM to SR20DETpower
its called chevy small block
SR20DETpower is offline   Reply With Quote
Old 12-15-2004, 11:01 PM   #11
GSR
GSR
i understand forced induction very well, however, air density does not define diplacement. therefore boost does not add displacement.
Old 12-15-2004, 11:21 PM   #12
SR20DETpower
Banned
technically hes right, the numbers basiaclly used to determine displacement are stroke, bore, and # of cylinders....
all a turbocharger does is allow the engine to burn air more effectively, compensated with proper timing, and more fuel ... you get power
Old 12-16-2004, 11:20 AM   #13
nissanfanatic
240SX Guy
Look at it this way:
When you add 7psi to the intake manifold, you get a pressure ratio of 1.47. And after you go through all of the temp rise stuff, you get a density ratio of about 1.27. Now the KA with a guestimated VE of 80% flows 218.4CFM. Multiply that by 1.27 adn you get 277.7CFM. Divide that by 61.02 to convert to liters and you get 4.5l. So you are effectively flowing as much air as a 4.5l engine.
-Cory
12.6@122mph
Old 12-16-2004, 08:42 PM   #14
GSR
GSR
same shit guy, flowing more air doesnt raise displacement. by your logic a i/h/e setup would also raise displacement.
Old 12-16-2004, 09:05 PM   #15
D-Bo
D-Bo's Avatar
if you think about it in a not so literal sense, its true. at 101.3kPa, you have 2.4L of air right? well if you increase the pressure by 50% then you're getting one and a half times the air in the same area, which if it was put into a balloon, would expand to about 3.0L of air at 101.3kPa. i don't know if you got that but whoever did, you'll understand why nissanfanatic said 'more displacement'. displacement isn't just in cars, its the physical area that something takes up.
Bookmarks
Google
Web AF
