Car problems
Pages : [1] 2
Hanster24
12-15-2004, 10:41 AM
Hi, i just bought a 89 240sx, it has 122k miles on it, it Automatic, it worked fine for about 2 weeks, i bought it on Nov. 22nd, 04. I wanted to do a burn out, but i had the grear on "2" by accident, i held the break down and reved my car, the car didnt move or burnout, then i noticed the gear, and i thought i put it in Drive, but it I put it in Neutral, reved up, then i was like, for get it, lets go get some gas, cus my car was almost on empty, i turned my car around and it stalled! I tried to turn it on, it wont, so I call Kyle over, and he unplugs my Fule pump fuse, and trurned it on till it worked. The car was idleing at 1500, so we drove it to his house, and Kyle and his dad, put back my stock air intake, " i had an aftermarket air filter" they said the their was a Sensore not bluged in, and the aftermarket part doesnt have the Sensor in it. Next day i drove it to work, it ran fine, on my way home, it wanted to stall at a stop sign, and when i first press the gas, it acts like it wants to stall, then, i drove it to a gas station, filled up gas, and it didnt start, i called my brother over, he tried, nothing, i bought this fule intake cleaner for like $1.50 form the gas station, and i put in in my gas tank, the car is still not turning on, it wants to when i turn the key, but it doesnt. I left the car at the gas station over night, next day the car worked, its been working.
I took the car to Nissan, they said i need this :
1.) Car has bad Temp Sensor Connector ( Corroded ) repair - $78.00
2.) Bad AIV Valve, Box, and Hose - $372.00
3.)Bad Air Flow Meter - $568.00
4.)Tuneup w/ NGK PLugs - total of $55.00 for spark plugs, wiers, and
smthing els - 149.95
My car doesnt move as fast as it did, and i had a 100lb sand bag in the trunk, befor i tried to do the burn out.
I NEED HELP!
TatII
12-15-2004, 11:16 AM
sounded like a bad MAF to me, or a Bad aiv. valve. you can buy a used MAF at a junk yard for a fraction of the price and install it yourself. i bought my 300ZX MAF for only 100 bucks.
Hanster24
12-15-2004, 11:37 AM
MAF? i have no idea what that is, sry, i dont know cars at all, i just need help!
Chuki_breath
12-15-2004, 01:33 PM
i wouldnt recommend doing burnouts in an old ass auto 240. Something is bound to break. Did you say you were doing neutral drops???? i strongly dont recommend that. Just start fixing everything they said one by one...if the problem goes away then you dont have buy everything they said.
GSR
12-15-2004, 05:13 PM
"i got 99 problems but a bith aint one...hit me :P
doesnt sound like the burnout had much to do with any of the problems the nissan stealer diagnosed. a maf is a mass airflow meter (sensor), that lets your ecu know how much air is flowing into the engine so it will know how much fuel to add to the mixture. the no start problem could be due to that. the high idle is probably the AIV (Air Idle Valve). search ebay or local junk yards for either, prices from dealers are ridiculous. both are quite easy to install
Hanster24
12-16-2004, 11:26 PM
Aiv, can I install it my self at home?
One more thing, the previous owner of the car had an aftermarket Air intake, and some aftermarket lil inake thing AIV, so it was not connected to the Air filter "the aftermarket one", and he had shortend the length of the pipe that was comming form the AIV to the stock air intake, now i have a peice of thick rubber connecting my stock air inake and the AIV.
when im at a stop sign, or a red light, my car idles at 500, then it jumped to 600 - 700, then goes down, then it goes to like 900 - 1000, and when i turn the heat off it goes to 500 - 700 i dont even feel the car running...
befor i had all my problems my car was fast, it would pick up fast and go, but now it seems slow!
What is Seafoam, and what can i use it for?
nissanfanatic
12-16-2004, 11:47 PM
Get rid of the AIV. All it does is cause problems. Try cleaning the MAFS with a q tip and rubbing alcohol. Be very gentle when you do. Better yet, just spray some carb cleaner on the two prongs. Try wiggling the connection to the MAFS as well.
www.240sx.org has a lot of write-ups that could help you.
Hanster24
12-17-2004, 01:16 AM
Remove the AIV!!! dont i need that to bring "hot air" from the exhaust back to my engine to warm up smthing?
but if i dont need it, how do i remove it?
and can some one tell me what Seafoam is? please!
lucki17
12-17-2004, 01:34 AM
i have an 89' and it is doing the exact same thing, not as bad as yours though, im taking it into auto tomorrow hopefully i can figure out what is going on then ill tell you, does yours dip into 500 rpm when you break hard easier than if you slow to a stop? thats when mine does it, it has stalled once, but started right back up, im just taking it REALLY easy for now.
Hanster24
12-17-2004, 02:05 AM
yes, my car does the same thing, ill be looking forward to see what your mechanic says about it, i took mien to Nissan, they said $1200.00!!
Hanster24
12-18-2004, 05:32 PM
should i order the AIV Valve, Box, and Hose, and the MAF, or clean them?
and what about my temp sensor?
nissanfanatic
12-18-2004, 05:34 PM
Try cleaning them. What if your bill is only $10 for carb cleaner, rubbing alcohol, and Qtips? Much better than $1200 huh? Temp sensor you can test with a multi-meter. Read the 240sx FAQ for resistance of the sensor.
Hanster24
12-18-2004, 05:37 PM
ill try that, thanx
Hanster24
12-19-2004, 04:32 PM
k, i just took my air filter box apart, and their is a lot of black crap on the filter, it look like its comming from the AIV, because all that dirt is right under the hole of the aiv hose.
i have and after market filter, it does not have an air flow sensor tho, what i do?
D-Bo
12-19-2004, 04:38 PM
how does it not have an air flow sensor??
the mafs isnt ON the filter, its AFTER the filter.. the outside probably looks like a little black box.. about the size of a cell phone..(yeah thats not very descriptive but i can't think of anything the same size at the moment..)
lazyfcker
12-19-2004, 04:42 PM
how about the size and style of older box type motorola phones lol
logik23
12-19-2004, 04:52 PM
http://www.nissanperformancemag.com/march03/project200sx/images/maf.jpg
Hanster24
12-19-2004, 05:24 PM
k, here is some pics
http://files.automotiveforums.com/gallery/watermark.php?file=/501/271918all3-med.jpg
Hanster24
12-19-2004, 05:28 PM
their is also a nothor sensor in the metal part of the intake
Hanster24
12-19-2004, 05:43 PM
i tried cleaning the filter, i washed it in the sink with watter, can i use anythig els, its not getting any better!
D-Bo
12-19-2004, 05:57 PM
haha throw that filter out!!! its toast!! you can use it as toilet paper now!
you need a new one.. thats brutal.. and clean your aiv
Hanster24
12-19-2004, 06:02 PM
will, i have an aftermarket air filter, but, it does not have hose plug for the aiv, its just like a filter!
Hanster24
12-19-2004, 06:07 PM
can i use that, instead of the stock crap, even tho the AIV doesnt connect anywhere, i have a little filter thing that goes on the aiv too, it looks like an air filter, but thats as black as the stock air filter " used to be red", the previous owner had those 2 filters installed
D-Bo
12-19-2004, 06:25 PM
what do you mean?? you have a filter but it has no plug?? no filter has a plug.. is it a cone filter? is the smaller one a cone filter? i have the feeling that you're talking about an aftermarket cone.. which needs to be installed. but then again i really can't tell.. be a little more descriptive.. which 2 filters did the previous owner have installed?
nissanfanatic
12-19-2004, 06:30 PM
If it is on the engine side of the throttle body, it is the Throttle Position Sensor(TPS). www.240sx.org is going to have just about everything you need to know about tune-up stuff in better works than we can put it in.
Hanster24
12-19-2004, 07:27 PM
air filters
http://files.automotiveforums.com/gallery/watermark.php?file=/501/271918Image044-med.jpg
logik23
12-19-2004, 07:34 PM
Hey, D-Bo, looks like the little filter that's on your car.
D-Bo
12-19-2004, 07:45 PM
i think its the exact same thing..
hanster, whats your intake setup right now?? is it all stock? or did you want to add those two filters?
Hanster24
12-19-2004, 07:48 PM
i want to add the filters
Hanster24
12-21-2004, 03:29 AM
k, their installed, my car seems to want to stop running when i first start it, it idles at 490 - 550 rpms, but after i drive it or let it run for about 10 min, its fine, before the aftermarket air filter and the AIV filter, it didnt do that when i started it, it would want to stop or act like it want to turn off when ever i stop at a light / stop sign...
and the throttle feels diffrent, i dont get as much go as i did b4
i also cleaned the MAFS with a q-tip and alcohol
Hanster24
12-21-2004, 03:37 AM
i want to clean the aiv, but how do i do it?
and would i notice that its clean, even tho it dont plug into my air intake any more!
Hanster24
12-21-2004, 01:57 PM
I Need Help, My Car Wants To Stop Every Time I Stop On A Stop Sign, it would idle at 500 rpms, then go up to 900 - 1100, the quickly back down to 500 and it feels like it wants to stop.
pantlegz
12-21-2004, 03:03 PM
I'm having the same problem... but mine is cooling system related... stupid leaking water pump. Not that it's your problem but you might want to look other places that air intake, fuel, and emissions control.
Hanster24
12-21-2004, 03:25 PM
i just installed aftermarket Air filter for air intake and the AIV, and i also cleaned the MAFS with alcohol, but the air filters and the alcohol didnt seem to do anything.
i dont know what to do, my car has no leaks, i mean i dont see any spots of anything under it.
nissanfanatic
12-21-2004, 05:11 PM
Try wiggling the MAFS connection. Just go through the 240sx.org FAQ. It has to be something in there.
MechManZero
12-22-2004, 12:29 AM
This reminds me of initial d when iggy got the 85 single overhead cam levin. Hanster24, I'm not being mean but why the single overhead cam KA. Less power. Maybe someone researched head swapping or something like that. That sucks but anyway, you can still turbo it at least. www.KA-T.org (http://www.KA-T.org) has a section for you in their forums.
logik23
12-22-2004, 12:33 AM
Dude, your getting fuckng annoying man, I don't wanna be mean, but you don't have to put a little KA-T comment in every single thread!!!
MechManZero
12-22-2004, 12:36 AM
LOL it is in my sig and I'm gonna keep it there like it or not. I do check out both forums so I am not pushing people over to ka-t.org. I am simply enlightening
logik23
12-22-2004, 12:37 AM
Good, it's in your sig, then you don't have to include it in your posts.
MechManZero
12-22-2004, 12:56 AM
Well who knows who checks out the sigs anyway because people still talk about SRs when I pop up in forums.
Hanster24
12-22-2004, 01:16 AM
i got the car for $400, some times i like it, some times i dont, i just want it fixed, i just got hit in the back, some laddy smashed my bumber, and my trunk is all messed up, i just want to fix the idleing problem, i went on 240sx.org, and read what the said, and i also tried wiggling the MAFS connection, but nothing happend, i was going to take my aiv out and clean it, but im afraid to take it apart, and not know how to put it back!!
MechManZero
12-22-2004, 10:59 AM
Do you have any car buddies you can get to help you. I hate bringing my car to the shop. I rather do it myself. And take it apart. Don't be afraid. I would put each set of screws in different piles.
nissanfanatic
12-22-2004, 06:36 PM
Then just try spraying some carb cleaner in the hose thats supposed to run to your airbox.
Hanster24
12-24-2004, 02:35 PM
OK, i think i found were the problems is, i think.
almost every timei open the gas tank cap, to fill in gas, the tank relerase or sucs air, what i mean by that, when i open the cap, i feel and hear a release of air or mabye its pulling in air, im not sure.
usualy when i start my car, it would want to stop, but yesterday, my gas was almost on empty, it was on the first dot right befor the E, my car didnt idle too low, or go up, it ran fine from the min i turned it on, i drove about 12 miles, it was fine, i stoped by a gas station, open the cap for the gas tank, and their was that release or suction of gas, filled up like 6 gallons of unleaded gas. as soon as im making a left out of the gas station, my car started acting up, my idle was at 480 - 500 rpms, and it wanted to stop!!!
sRscooby
12-24-2004, 03:02 PM
my car does that too, the gas vacuum thing, i think that's common. however, mine doesn't have your problems
so that might not be the problem, but worth checking out
MechManZero
12-24-2004, 03:06 PM
That isn't a problem at all. Don't worry about that. A lot of cars from the 90's and up started doing that. It is common and its just because no air goes in the tank and the fuel pump draws out gas which makes it a little bit harder to unscrew the cap.
Hanster24
12-24-2004, 03:43 PM
will, after i fill up gas in my car, it acts up and would want to stop, but if im low on gas my car runs fine
could my fuel pump be going bad?
logik23
12-24-2004, 11:24 PM
Dude, there's suction because there pressure build-up in the tank to keep fuel pressure up, every single car does that. If you didn't have that, fuel could barely make it to the injectors.
Hanster24
12-25-2004, 03:36 PM
if i have a 1/2 a tank of gas, my car runs fine, but if i have any more than 1/2, it would idle at 480 - 500 rpms, and on every stop sign, it would want to stop, "the lights kinda dim out"
Hanster24
12-25-2004, 05:57 PM
i was just trying to clean the AIV, and 3 of the 4 screws broke?
what i do
Hanster24
12-25-2004, 06:30 PM
my aiv is so filthy, do i need it back in
lazyfcker
12-25-2004, 07:38 PM
well i would find out the exact screws that broke and replace them asap, then if you cant clean the aiv or looks damaged just buy a new one or do you have the aiv plug?
Hanster24
12-25-2004, 08:02 PM
k, i took my aiv out, " mabye i shouldnt have done that"
anyways, AIV it out, its all black on the inside, also the pipe that runs from the down pipe to the aiv is filled with black crap, is that normal?
and do i need an aiv?
i failed e-check, i had 4.8 CO, and the limit was 1.2
HELP
nissanfanatic
12-25-2004, 11:40 PM
Replace the screws at your local hardware store. It sounds like you are running kinda rich. Usually black all over is carbon from either too much fuel or not burning all of the fuel. Pull your plugs and check them. If they are black, then you should clean them or replace them. Try testing the coil as well. Pull the coil wire from the distributor and place the end of it close to a ground point on the car. I use the strut bolts. Try starting the car and watch for the connector to arc to the ground. It should arc pretty well and in a sequential pattern. Once every .15 seconds or so. If it seems weak or arcs erradically, replace it. My coil went bad and I expirienced surging, stuttering and such. Make sure your timing is correct as well. That would also be a factor. 20BTDC for KADE and 15BTDC for KAE.
Hanster24
12-26-2004, 06:47 PM
Here is my problems "Still"
1.) Car has stalled twice - i was trying to burn not "not nutral slams" - My frind came over, unpluged my Fuel Pump's Fues, he got it running, till next day it died right after i filled up with gas, i added some fuel injector cleaner in the gas tank, car still didnt work till next morning, it has not stalled since then.
2.) Car idles at 480 to 500 rpms when stoped at a light or a stop sign - most of the time it happens right after i fill it up with gas - I took the AIV out, the car still does the same thing. Right now the aiv is with my frind, he's cleaning it and replacing some screws i broke.
3.) I failed e-check, i got 4.8 CO the limit is like 1.2.
any1 know were i can find a manual for my car
its a 89 204sx "not a hatchback" auto - KA24E SOHC
Hanster24
12-30-2004, 11:20 PM
k, remember how i said i got hit in the back "car accedent", will, i took the car to a body shop, and after 4 days, i cheked on it, they said it cant be fixed, the chassis is messed up "from the inside of the trunk, and its too rusted"
will my car and problems are gone, but what should i get next?
monooxide
12-30-2004, 11:22 PM
man...that just takes us one away form one hundred on the how many out there thread :(
nissanfanatic
12-31-2004, 12:19 AM
Well thats a pretty sad story. Part the car out and get something else. Getting anything from the accident?
Hanster24
12-31-2004, 01:59 AM
not yet, but, what kinda car should i get next?
D-Bo
01-02-2005, 12:57 PM
a 240
