side to side rockingfood4me 12-14-2004, 07:51 PM my 87' ram rocks back and forth when slowing down to a stop or accellerating from a stop but onice i get to a certian speed it stops what is it and how do i fix it. BamaDodgenMX 12-14-2004, 10:19 PM Does it shudder? Also, does it rock side-to-side or front-to-back? BamaDodgenMX 12-14-2004, 10:21 PM Sry, didn't notice the title. Well, is it a jerk, like a skip or..? food4me 12-17-2004, 11:30 AM it feels more like a jerk at slower speeds and feels like its coming from the back also it feels like its still there a higher speed just less notice able. fredjacksonsan 12-17-2004, 11:42 AM When you say rocking, is it pronounced, like 3 or 4 inches, or a smaller movement? I'd Check tires for roundness and balance, and the brake drums to see if they need to be turned. food4me 12-17-2004, 04:34 PM it is pretty "pronounced" jrmcx 12-18-2004, 09:45 AM Bent wheel BamaDodgenMX 12-18-2004, 09:07 PM Axle problem maybe? fredjacksonsan 12-19-2004, 12:26 PM Sounds like it's time to jack up the rear end and run it a bit; you should be able to see whatever is bouncing around. food4me 12-19-2004, 01:56 PM do it think it can wait till spring its kinda cold here in michigan fredjacksonsan 12-19-2004, 10:47 PM Depends on a couple of things -- does it feel like it's going to shake apart and can you find a "friend" with an enclosed garage? Wait a sec. Michigan. Has it snowed alot? Check your rims, and see if there is snow caked in them. I've had that vibration with snow in the rims. food4me 12-19-2004, 11:08 PM the snows on and off sometimes there snow sometimes there isn't it doesn't matter dry or blizzard still there do u think it could be w/ the wieght i put in the back fredjacksonsan 12-20-2004, 04:42 PM Don't really understand your last. Did you say that there IS snow caked in your rims? If so, I'd say that's your problem. Weight in the back of your truck? That shouldn't cause a vibration, especially side to side. Have you had an opportunity to get the truck up on jackstands to run it yet? food4me 12-20-2004, 11:09 PM no snow on rims no i haven't gotten it on jack stands im try to get a hold of my uncle who has a big garage fredjacksonsan 12-21-2004, 11:26 AM You could always get a buddy to follow you and watch the tires when it's vibrating. BleedDodge 12-21-2004, 01:29 PM Slipped belt on one or more of the tires? fredjacksonsan 12-21-2004, 01:57 PM It's one of the things in the post, either yours or the wheel or axle. Seems like he hasn't done any checking just yet. food4me 12-22-2004, 12:05 AM i've been kinda busy lately but i will post and update when i get a chance to look at it it my not be till after christmas BamaDodgenMX 12-22-2004, 07:12 PM Would a slipped belt create that much of a rock/vibration? I believe he said/meant about 2 in or more side to side.. That's quite a ways. And another thing.. if it were a bent wheel, axle problem or slipped belt, would it not continue even if you reach a certain constant speed? fredjacksonsan 12-23-2004, 08:26 AM You're right there, Bama. All the problems we've mentioned would likely cause a vibration at all speeds, not just slowing down. Guess we'll have to wait for more info. BleedDodge 12-23-2004, 11:00 AM On one of the work trucks, a Chevy 3/4 ton, it would vibrate so badly around 40 mph. You could hang around at speeds just below, or just above 40, but if you drove constantly at that speed it was just unbearable. If you had a coffee mug in the cupholder when you started off, it would stay until you got up to that speed, and then it would be spilling everywhere. It was that bad. Turned out it was the passenger side steering tire that had a slipped belt. If what is happening here is happening at all speeds, then it's probably something worse and more dangerous. I don't know what else to tell you. fredjacksonsan 12-28-2004, 11:24 AM He finally got someone to drive behind him, it's the right rear wheel is vibrating; new post was started. BleedDodge 12-28-2004, 02:41 PM fredjacksonsan 12-28-2004, 02:46 PM Ayup. Automotive Network, Inc., Copyright ©2012
