is something wrong...?xcusememisswyn 12-14-2004, 09:43 AM out of my back left brake and wheel smoke was coming... smelled awful... i was just messin around on some backroads...it calmed down after a bit but its a new car for me and i dont knoe if my brakes were just gettin used to hard or if somethin serious mite be a problem 1996 240sx se xcusememisswyn 12-14-2004, 09:55 AM my idle on the car is also rough... it goes from like 750 up to a grand and then down to 750 over and over... is that bad and is there a way to fix it? TatII 12-14-2004, 11:29 AM the smoke is your brakes smoking from braking hard. it does that with hard drivin sometimes. it also does it if you drive with the e brake up, or have one binding brake caliper. about the idle, check for vacuum leaks. zauber 12-14-2004, 03:42 PM you running your ac? mine does that when my ac or heat is on. xcusememisswyn 12-14-2004, 03:43 PM yah i noticed when i was in it today that i didnt have the problem unless i did somethin usin a lot of battery... i just got the car yestarday so ill have it looked at and make sure everything is good AWDSR20 12-14-2004, 03:54 PM agree. TatII 12-14-2004, 03:55 PM one of hte vacuum lines that goes to your idle air control valve must've came off. try looking for the vac line near the throttle body. it should be a pretty one. Automotive Network, Inc., Copyright ©2012
