91 teg engine swappingnew_teg91 12-13-2004, 11:47 PM i have a 1991 integra and i want to do an engine swap on it. I was thinking a B18C1. Does it fit or can it fit? whtteg 12-14-2004, 12:10 AM Yes it will fit, you will need all of the following: GSR ECU GSR motor B18C1 wiring harness's mounts and a manual on your car will help a great deal. I would suggest www.helminc.com (http://www.helminc.com) for the manual. new_teg91 12-14-2004, 12:20 AM what if my car is automatic and i want to convert it into manual whtteg 12-14-2004, 12:23 AM look in the FAQ at the top of the page, post #20 which is the 5th post down on the 2nd page. new_teg91 12-14-2004, 12:36 AM i went to the FAQ but some stuff about vbulletin came out new_teg91 12-14-2004, 12:52 AM what tranny do i use for the b18c1 engine gsr916 12-14-2004, 01:31 AM there is another post almost exactly like this one that is pretty current. I believe whtteg made the point of making sure the tranny you pick is a cable tranny not hydraulic. If you are feeling lucky, look for like a 93 GSR or XSi tranny. You'll be shifting a lot but ur shit will be fast. new_teg91 12-15-2004, 10:10 PM if i put b18c1 from a 94 teg can i still put the 93 gsr tranny whtteg 12-15-2004, 10:12 PM if i put b18c1 from a 94 teg can i still put the 93 gsr tranny Yes you can. All B series trannies will bolt up to all B series motors. new_teg91 12-15-2004, 10:14 PM do u think that doing the 5 speed conversion is hard whtteg 12-15-2004, 10:18 PM do u think that doing the 5 speed conversion is hard I have never done the auto to manual conversion personally. I always buy manuals from the start lol. I don't think it would be that hard for you to do if you are able to swap the motor. new_teg91 12-15-2004, 10:19 PM since im going to do the swap, my car comes with a b18a1 stock, do u think the b18c1 will just be a direct drop in, or do i still have to get different motor mounts??? new_teg91 12-16-2004, 08:37 PM ok so i got some info now together tell me if it sounds good? I buy a b18c1 v-tech engine and i buy either a b16 tranny or a 93 gsr tranny. What do you think?And will the b18c1 do a direct fit in my engine bay or do i need mounts? das_beast 12-18-2004, 12:55 AM is it possible to put a RB25DET engine in a 95 teg? whtteg 12-18-2004, 08:41 AM is it possible to put a RB25DET engine in a 95 teg? You don't need to ask the same question 3 times, one time will get you an answer. Check one of your other posts you have the answer to your question from civicspoon. Automotive Network, Inc., Copyright ©2012
