Engine Code P0753? NEED DIAGRAMS! ANY RECOMMENDATIONS!!HELP FAST!!Kiyrah 12-13-2004, 01:52 PM My 01 Dodge 2500 L6 5.9 Turbo Diesel will not shift out of overdrive. IT keeps throwing the engine code P0753 at me. I fugire that it is a harness or solenoid problem but I need a really cheap wiring diagram so that I can fix this without breaking my bank. ANYONES help will be much appreciated. THANK YOU THANK YOU!! Kiyrah :confused: whoamioitsme 01-13-2005, 11:40 PM 753 Overdrive solenoid control circuit problem (transmission relay circuit in RE transmissions.) i am kinda sure this is the right 1 hope it helps ya john m 01-19-2005, 07:20 PM My 01 Dodge 2500 L6 5.9 Turbo Diesel will not shift out of overdrive. IT keeps throwing the engine code P0753 at me. I fugire that it is a harness or solenoid problem but I need a really cheap wiring diagram so that I can fix this without breaking my bank. ANYONES help will be much appreciated. THANK YOU THANK YOU!! Kiyrah :confused: I have a hand held scanner and cd with codes. They also say:Shift Solenoid A Circuit Electrical Overdrive Solenoid Good luck. John M. Dan89rs 07-05-2005, 06:06 PM i know this is a fairly old post. and i dont mean to take it over but this is the same code i got on my moms '98 1500 5.9 auto. I also need help. we're going out of town in the morning, and dont want any problems. if it werent for the check engine light coming on i wouldn't have noticed it. it drives the same as usual. shifts into overdrive, and kicks down when mashed on. auto parts store said OD solenoid too. the computer didnt say if it was bad, if it was stuck, or if it fell out of the dang truck... please help me, guys. im willing to do a tranny fluid, filter and maybe solenoid change tonight; as long as i can afford it. Automotive Network, Inc., Copyright ©2012
