removing Accord 94 Stereomyahya 12-13-2004, 10:12 AM Hi all, does any one know how to remove factory fitted radio from honda accord 94 ? i went upto removing many things !! including trim for gear, hand break , front panel , AC panel but still could not pull the radio out . any DIY tips or instruction would be appreciated . Thanks yoyo 94cordvtec 12-26-2004, 12:19 AM first off take off the center console with the armrest by takein the screwes out under the flap in the bottom of the storage part then the screw at the base of the black trim and take out the ash tray next to the cigarette lighter it just pulls out and take out those screws . get a small flat head and pull out your hazard switch and the other slot if u have a switch there. then that whole black peice of trim should pop right out it make take a little force at the top to pop it out but as far as i can remember theres only two screws, then there should be a screw under the storage bin under the tape player and there may be one on the top or side but all in all thats the only thing u have to do if ur swapping for a single cd player just buy a dash kit and trim it and u can still use the storage tray under it, it just takes to riggin to make it work right but it still looks stock and stays in, hope this helps. Automotive Network, Inc., Copyright ©2012
