resetting ECU
gsr916
12-12-2004, 11:15 PM
just to make sure, i warm up the car. take out the 10 amp ECU fuse for a few mins, put it back in and let the car idle for about 10 mins?
whtteg
12-12-2004, 11:16 PM
Yea but you can just let it idle for about a min or so, ten is kinda long IMO.
gsr916
12-12-2004, 11:28 PM
k tight. i havnt done this and i have i/h/e and its running hella rich (ive mentioned this lol). resetting will possibly fix this, correct?
whtteg
12-12-2004, 11:30 PM
It may or it may not. Unfortunetly for you, your car is OBDII so some mods screw with the ECU.
gsr916
12-12-2004, 11:38 PM
if it didnt, i guess i could advance my timing...
Crippy
01-21-2005, 12:16 PM
or you can take the negative battery wire off for about 5- 10 minutes then hook it back up and it will reset ... its alot easier i think ...
kornflakes28546
01-21-2005, 05:44 PM
:iagree:
casperGSR
01-21-2005, 07:54 PM
disconnecting the battery on obdII cars will only erase the volatile RAM memory, however it won't erase non-volatile RAM, ROM, PROM or any DTC's that are stored in the ECU... OBDII setups have two different types of fuel trims, short term and long term even if you do reset the ecu with a scanner the system to an extent is adaptive with it's fuel maps and will eventually go back to where it is right now... out of curiosity what's your air fuel ratio running right now anyways?
casperGSR
01-21-2005, 07:57 PM
just realized this post was a month old.... my bad.
gsr916
01-21-2005, 09:49 PM
well... it is still running rich anyways. i really dont know what i can do about that... besides take advantage of it and advance the ignition timing.
